GSX-S 750
Re: GSX-S 750
Taipan wrote: Tue May 10, 2022 10:31 am
WHat about Hagon? They'll build a shock to your weight and requirements.
I've had Hagon shocks in the past and not been impressed by their build quality.
Marc from Brooks Suspension has also suggested Nitron (because he sells them) and has said the build quality is better than YSS and they do a good shock in the £700 - 800 range.
So my conclusions so far are if I want to spend under £400, YSS is best, if I want a £700 shock, I need to think about what I want.
Has thanked: 12607 times
Been thanked: 8537 times
Re: GSX-S 750
Le_Fromage_Grande wrote: Tue May 10, 2022 9:56 am Went out on it last night to the local VJMC meeting which meant going along some fast bumpy roads, the rear end wasn't great, feeling over sprung and under damped, so today I'm investigating rear shocks, do I buy the £325 YSS or the fully adjustable £771 YSS, I'm leaning towards the fully adjustable.
Try to get the standard stuff set up properly. You might spend money on new stuff then still need it set up properly.
Re: GSX-S 750
Yorick wrote: Tue May 10, 2022 11:25 am
It's only got a preload adjuster, it's pretty basic, I've either got a bit too much preload or preload about right but it's bouncy because there's not enough damping - the bike has done 11,000 miles, so it might have been better when it was new.
Been thanked: 15492 times
Re: GSX-S 750
neither, you call Paul at Black and White bikes who's @Sideshow Pob
and tell him we sent you :) It'll be cheaper.
Re: GSX-S 750
weeksy wrote: Tue May 10, 2022 12:19 pm neither, you call Paul at Black and White bikes who's @Sideshow Pob
Just messaged him
Re: GSX-S 750
Le_Fromage_Grande wrote: Tue May 10, 2022 1:28 pm
Just messaged him
He's not been on here for 4weeks, i'd ring him.]
Just pinged him on PB forum.
Re: GSX-S 750
Thought I'd have a fiddle with the adjusters when I got home from work, looked at it and there's 10mm of preload adjustment on the front and 8mm on the rear, so hardly worth bothering with, I've wound the adjusters right out and I'll see what it's like.
I must have been deluding myself when I thought I could tell the difference between single preload steps, my arse isn't sensitive enough to tell the difference in 2mm of preload, in threaded shocks I usually work in 10mm increments.
Sideshow Pob
Has thanked: 4 times
Been thanked: 28 times
Re: GSX-S 750
Post by Sideshow Pob »
Sorry fellas, it’s a busy time at the moment and I don’t get much time to check messages and stuff.
But I can do really, really good deals on YSS shocks as well as being a K-tech and Nitron dealer.
YSS is great quality to be honest it’s just as it’s assembled in Thailand they save on overheads when compared to Nitron and K-tech.
It’s best to call me on 07977242526 during the day when I’ve got all the information in front of me and I can sort out some great prices for you.
Re: GSX-S 750
Paul has done me an amazing deal on a top of the range YSS shock that I couldn't say no to, new shock has been ordered.
Re: GSX-S 750
Le_Fromage_Grande wrote: Wed May 11, 2022 10:23 am Paul has done me an amazing deal on a top of the range YSS shock that I couldn't say no to, new shock has been ordered.
See, sometimes listening to me does help :D
Re: GSX-S 750
weeksy wrote: Wed May 11, 2022 10:28 am
I'm not buying a KTM :D
Sideshow Pob
Re: GSX-S 750
And it would have been even more amazing if you hadn't pointed out I got the decimal point in the wrong place! Thank you.
Re: GSX-S 750
Bike is better handling with the preload as soft as it will go, but the rear damping is having trouble stopping the rear spring from bouncing about over a series of bumps, weirdly the front damping feels fine.
New rear tyre fitted yesterday, getting the rear wheel out and in is piss easy, definitely better than all of the old bikes I have, though I can't see why as the design is the same on all of them.
Re: GSX-S 750
New tyre has made the handling better, running 37psi in the rear
Re: GSX-S 750
Hurt my back so not going far today, thought I'd try my luggage out, took about 20 minuters to put the frame on the bike, they're quit wide, but you don't notice them when riding
Re: GSX-S 750
Side on picture, what's the link between the aircraft and the bike?
Re: GSX-S 750
They've both got 2 seats
Re: GSX-S 750
Mr. Dazzle wrote: Thu May 26, 2022 1:27 pm They've both got 2 seats
Not the link I was thinking of
Re: GSX-S 750
Is it the black version of the bike being called Phantom?
Re: GSX-S 750
The cockpit is an F4 Phantom?
Suzuki make Phantom editions of their bikes... which yours isn't one of?
