Need Help...
Annieclover2
Has thanked: 3 times
Been thanked: 1 time
Need Help...
Post by Annieclover2 »
Hey everyone,
My motorcycle 2017 rusi gala has no power i have checked the battery its ok and changed the main fuse but still no power. My question is what should i check next? Maybe i am overlooking something but any thoughts from you all would be appreciated.
Re: Need Help...
Check the terminals on the battery and the fuse carrier. And check that the battery has power.
Has thanked: 8044 times
Been thanked: 5695 times
Re: Need Help...
So, press the starter and nothing at all happens? No clicks or anything? Was the fuse you replaced actually OK? How did you check the battery?
Do the lights come on (if they'll actually run off the battery)? As you say no power, I assume not. So it seems pretty fundamental...as David suggested check connections inc to the ignition if they're accessible.
Been thanked: 9496 times
Re: Need Help...
For £500 plus expenses....
Has thanked: 779 times
Been thanked: 3217 times
Re: Need Help...
Switch the kill switch, and check the power band hasn't faded
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Re: Need Help...
Post by Bigyin »
First step is check the kill switch ;)
Re: Need Help...
Bigyin wrote: Mon Apr 18, 2022 7:36 pm First step is check the kill switch ;)
Took me 3 days (and an electrician neighbour) to solve that one after my bike had been garaged for a while. :( Switch was in the correct position and the engine would spin. Quick waggle cleaned the contacts and started first time. :shifty:
Annieclover2
Re: Need Help...
Thanks everyone for suggested me.
