Shiny new bike day
- MingtheMerciless
- Has thanked: 3644 times
- Been thanked: 2502 times
Re: Shiny new bike day
Front wheel speed sensor had glitched, ECU cleared and all good (so far). Time to buy an OBD reader.
- Been thanked: 9495 times
If you get a Bluetooth one, The Torque app is brilliant for reading and resetting code and viewing live sensor data.
Healtech do one for the Z1000 for around 60 quid,one for yours should be similar.MingtheMerciless wrote: Fri Nov 12, 2021 3:37 pm Front wheel speed sensor had glitched, ECU cleared and all good (so far). Time to buy an OBD reader.
- MingtheMerciless
Lovely muddy bit of lawn thanks to the pidgeons trashing it and over it went this morning. By fook is it a heavy beast to get upright, I was seeing stars and my back was none to happy.
Bike is fine, mud, bungs and slo mo drop saved it.
r1flyguy
- Has thanked: 67 times
- Been thanked: 77 times
- Contact:
All the weight was the fuel in the tank !!!MingtheMerciless wrote: Sun Mar 06, 2022 8:24 am C870AEFA-EB50-4F97-BC7F-A6CB9FD17DFA.jpeg
Glad theres no damage
- Has thanked: 5954 times
- Been thanked: 3572 times
I looked at the pic and first thought was 60 degrees at 3c temperature bloody hell! Then the penny dropped.
Glad the bikes ok. That's the reason bungs were first on my list it weighs a ton more than the Duke
Have you been having any bother with oil gathering in the airbox,or being fired out a breather? Seems fairly common,with various suggestions for a cure from owners,but not Kawasaki.
https://www.zh2forum.com/index.php/topic,669.0.html
- MingtheMerciless
The oil bottle at the bottom of the engine breather drain does fill up, its just a matter of keeping an eye on it and emptying it when it's full. I wonder if that's neglected then the oil can back up.
I've had to empty it three times in the last two years. From what I've read most of the problems come from too much oil in the engine, I think there is a technical directive from Kawasaki saying not to fill the oil up to the top of the sight glass level after an oil change.
- MingtheMerciless
7600 mile service today(more like 8500 due to the wait for a service slot), place your bets on how much............
What all do they do?
The supercharger impeller is likely checked for endplay,which is labour intensive. I don't know what else,but you will probably pay for around 4 hours labour plus parts.
What does the dealer charger per hour?
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
Not as intensive as what happens if they discover play, one assumesSkub wrote: Fri Jul 15, 2022 8:13 pm What all do they do?
- MingtheMerciless
£447.55, rear brake fluid change as well and diagnostic check as the KIBS warning light has come on a few times.
Supercharger check is at 15K
Then fuel pump replacement at 20kMingtheMerciless wrote: Sat Jul 16, 2022 10:34 am £447.55, rear brake fluid change as well and diagnostic check as the KIBS warning light has come on a few times.
- MingtheMerciless
la la la la I'm not listeningSkub wrote: Sat Jul 16, 2022 11:04 amThen fuel pump replacement at 20kMingtheMerciless wrote: Sat Jul 16, 2022 10:34 am £447.55, rear brake fluid change as well and diagnostic check as the KIBS warning light has come on a few times.
Supercharger check is at 15K![]()
Recall I came across recently,dunno if it affects your bike,but sounds like one not to ignore.
https://www.vehicle-recall.co.uk/recall/RM/2021/022
- MingtheMerciless
Another "exciting"commute home today. Car decided at the last minute to turn right around a roundabout from the "slow lane" of a dual carriage way roundabout as he was on the point of carry straight on, no indications, just a last minute swerve. I was coming up on the outside, large handful of brakes (could've been more in hindsight as I didn't trigger the ABS). Smacked his rear drivers side bumper but managed to stay upright. No damage to the bike but his plastic Ago bumper was looking a bit sorry for itself. Stern words of advice offered to driver who revealed they were 6 hrs into a return journey from Cornwall and he was tired!! FFS!
- Has thanked: 19576 times
- Been thanked: 4950 times
Really glad you're ok.MingtheMerciless wrote: Sat Aug 13, 2022 9:59 pm Another "exciting"commute home today. Car decided at the last minute to turn right around a roundabout from the "slow lane" of a dual carriage way roundabout as he was on the point of carry straight on, no indications, just a last minute swerve. I was coming up on the outside, large handful of brakes (could've been more in hindsight as I didn't trigger the ABS). Smacked his rear drivers side bumper but managed to stay upright. No damage to the bike but his plastic Ago bumper was looking a bit sorry for itself. Stern words of advice offered to driver who revealed they were 6 hrs into a return journey from Cornwall and he was tired!! FFS!
The bit in bold is a big reason that most locals avoided the M5 Weston/B'water area on bank holiday weekends with everyone from oop north heading to the south west! Guess it's similar but further north on the return? WTF don't people just stop for sensible breaks ??
