Der Panzer
Been thanked: 7528 times
Re: Der Panzer
Couchy wrote: Sun Feb 20, 2022 3:17 pm Weather crap so had another couple hours to finish this off. Preload adjuster fixed, new number plate swapped, indicator repair and front calipers removed cleaned and new pads fitted. Checked sag on front and rear shocks and gave it a quick wash. Think that’s about the lot it’s now serviced with new tyres brakes and suspension and ready to be sold👍
EFA
Couchy
Has thanked: 326 times
Been thanked: 2173 times
Re: Der Panzer
Post by Couchy »
It’s not for sale 👍😄
Re: Der Panzer
Good, cos you need to lube the splines first!
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
Re: Der Panzer
Post by Asian Boss »
KungFooBob wrote: Sun Feb 20, 2022 3:25 pm
EFA
He offered it to me for £3400!
I'm letting him fix it up real nice before I come to collect it. :thumbup: Ideally I'd like the frame powder coating too. And a supercharger.
Couchy
Re: Der Panzer
Post by Couchy »
New exhaust fitted today, that's it all done...apart from the 17's waiting to go on :)
Couchy
Re: Der Panzer
Post by Couchy »
Had a long ride today, no explanation but I think this bike is superb. Stopped by at the farm where our storage is and had a play on their roads then a play with photoshop....
Has thanked: 7817 times
Been thanked: 2527 times
Re: Der Panzer
Couchy wrote: Wed Feb 23, 2022 12:06 pm Had a long ride today, no explanation but I think this bike is superb. Stopped by at the farm where our storage is and had a play on their roads then a play with photoshop....
:D :D :D
Has thanked: 6376 times
Been thanked: 4753 times
Re: Der Panzer
Does yours try to pull to the left when you photoshop it? Mine always did as soon as I selected the lasso tool. :(
Has thanked: 2551 times
Been thanked: 6244 times
Re: Der Panzer
You can tell it's a photoshop 'cause it's not pissing it down and blowing a gale.
Couchy
Re: Der Panzer
Post by Couchy »
Count Steer wrote: Wed Feb 23, 2022 12:44 pm
If you rotate the mouse quickly it veers left but if you roll on slowly and then open quickly it negates it to some degree 👍
Has thanked: 15952 times
Been thanked: 10244 times
Re: Der Panzer
You've still got it??
Couchy
Re: Der Panzer
Post by Couchy »
Had to sort the leaky fork seal today, with forks in the bike it's one bolt on top of fork leg. Once undone the stanchion slides down out the top yoke pushes to one side and slides straight out the top. One clip later and the fork seal is out. A 15 min job tops :)
One other issue with the raised suspension is the side stand is too short, 15mins later with the lathe a lump of nylon and we have a solution......and the bike now has a name, Clubfoot :)
Has thanked: 5450 times
Been thanked: 13086 times
Re: Der Panzer
:delete: :flame:
Tricky
Has thanked: 2564 times
Been thanked: 2680 times
Re: Der Panzer
Post by Tricky »
Couchy wrote: Thu Feb 24, 2022 3:49 pm Had to sort the leaky fork seal today, with forks in the bike it's one bolt on top of fork leg. Once undone the stanchion slides down out the top yoke pushes to one side and slides straight out the top. One clip later and the fork seal is out. A 15 min job tops :)
Love it - was great to see it in the metal yesterday too :thumbup:
And although admittedly my effort arguably isn't as well engineered or durable as yours (mainly as it's made of wood :lol: ) , it's equally functional- great minds eh! 8-)
Couchy
Re: Der Panzer
Post by Couchy »
First proper dry ride, on the clear bits of road I found i got to ride as hard as I like to on the road and the GS really handles superbly. It’s quick enough with the new map and pipe.
The only downsides it’s not as shiny and new as I like and the exhaust needs it’s baffle 👍
And the other fork seal went today lol
Couchy
Re: Der Panzer
Post by Couchy »
Built 17” wheels up today, that’ll be tomorrow’s job then
Couchy
Re: Der Panzer
Post by Couchy »
Fitted the 17's today, front end was nearly 2" lower so gained 1" adjusting the ride height on the shock. Rear was also 1" closer so looks like geometry is similar. Bike sitting a little lower so side stand needs modding again. Also the front mudguard needs changing but I'll ride it first. Weighed the wheels too and ready to use the front is 2kg lighter and the rear 1.5kg so a 3.5kg weight saving.....irrelevant really but since buying it I've unbolted over 12kg of 'extras' and changed the exhaust and cat so it's over 21kg lighter and around 12kg lighter than standard ;)
ImageUntitled by Tony H, on Flickr
Re: Der Panzer
Couchy wrote: Thu Mar 10, 2022 11:59 am Fitted the 17's today, front end was nearly 2" lower so gained 1" adjusting the ride height on the shock. Rear was also 1" closer so looks like geometry is similar. Bike sitting a little lower so side stand needs modding again. Also the front mudguard needs changing but I'll ride it first. Weighed the wheels too and ready to use the front is 2kg lighter and the rear 1.5kg so a 3.5kg weight saving.....irrelevant really but since buying it I've unbolted over 12kg of 'extras' and changed the exhaust and cat so it's over 21kg lighter and around 12kg lighter than standard ;)
That mudguard does look odd.
Hopefully it should still ride ok, be interesting to know what the difference is. What size is the OE rear?
Did you get a 5" or 5.5" width rear? IIRC the R1150R has a 5" rear (where the Rockster/K1200RS/R1100S have the 5.5") and takes 170 section tyres, rather than 180. Not sure if that limits your tyre choice or not.
Re: Der Panzer
Rockburner wrote: Thu Mar 10, 2022 12:02 pm
when you say 'odd' you mean hideous ? enormous ? comical ? or a combination of all ?
Couchy
Re: Der Panzer
Post by Couchy »
5" rear with a 170/60, standard was a 150/70. It's got the same geometry as before (I'd set it 1" higher at back) but I'm assuming it'll turn a bit slower with the wider tyres which is no issue as it turned very quick before. Although the tyres are a much steeper profile so riding is the only way and I haven't got time today lol
