Monster rustoration
crust
Has thanked: 604 times
Been thanked: 515 times
Monster rustoration
Post by crust »
Been tidying up the garage ahead of putting a new roof on and leaning in the corner is my old Ducati Monster where I left it back in 2014 after an Italian touring holiday.
I needed to move it so pumped the tyres up and took the cover off and pushed it into the garden, while its out may as well give it a wash.
Now its clean may as well.....
So here we go, not a full cosmetic job, haven't got time for that, just back on the road running then do the cosmetics later.
Has thanked: 5450 times
Been thanked: 13086 times
Re: Monster rustoration
I'll transform that tank into gleaming red loveliness in an hour or two.
crust
Post by crust »
Before
Image20200705_154146 by crust, on Flickr
After
Image20200705_170120 by crust, on Flickr
crust
Post by crust »
There's something to be said for the preservative qualities of manky chain lube
ImageSwinging arm before by crust, on Flickr
A dose of SDOC, blast of rhino goo and tadaaa
ImageSwinging arm clean by crust, on Flickr
Been thanked: 7528 times
So why did you leave it under a cover for 6 years?
crust
Post by crust »
Engine could do with a tidy up :)
Image20200705_170211 by crust, on Flickr
Image20200705_170221 by crust, on Flickr
crust
Post by crust »
KungFooBob wrote: Tue Jul 07, 2020 9:37 pm So why did you leave it under a cover for 6 years?
I bought a 996, then a GSXR1000, Superduke, then got back into trail riding - KTM 350 and mountain biking
So it just didn't get used and kind of got forgotten.
crust
Post by crust »
Frame has suffered developed red rash all over :(
Image20200705_170235 by crust, on Flickr
Tbh mate, once we throw some rubber at it and a set of belts, it's well on its way.
Happy birthday
https://www.ebay.co.uk/itm/Brake-Pads-D ... SwsYpaExTo
crust
Post by crust »
With a fair bit of trepidation I decided to have a look at the carbs to see how bad a mess of gunge lurked within, so out with the allen keys and in we go.
Luckily I'd replaced pretty much every nut and bolt on the bike with stainless and used copaslip on all of them.
10 minutes later and we're at the carbs.
Image20200705_180700 by crust, on Flickr
and they're on the bench
Image20200705_182131 by crust, on Flickr
weeksy wrote: Tue Jul 07, 2020 9:47 pm Tbh mate, once we throw some rubber at it and a set of belts, it's well on its way.
Happy birthday
Yeah, don't run it for too long without changing the belts.
Which is piss easy on a SOHC aircooled Ducati.
crust
Post by crust »
Off with the float bowls and WOW, really, that clean inside, gob well and truly smacked.
Image20200705_182608 by crust, on Flickr
Lol fuck the pads, I'm booking you on Pembrey instead, it'll be done by the weekend
crust
Post by crust »
KungFooBob wrote: Tue Jul 07, 2020 9:49 pm
Spot on, mate. Not even going to bother until belts are changed, oil drained, filter changed and motor spun over for a while with fresh oil. It's sat for a while so a week or two longer isn't going to hurt, not worth the risk.
crust
Post by crust »
Gave the fairing a polish and the screen a buff up, then took it off and hung it up.
While I was there gave the headlight rim a polish.
Image20200706_174031 by crust, on Flickr
Image20200706_182930 by crust, on Flickr
crust
Post by crust »
Took the front wheel and disks off to give them a proper clean.
Will finish them, give the calipers a good clean, change brake fluid and give the carbs a strip, blow through etc.
To be ordered list so far:
Battery
Belts
Belt tensioner bearings (if required, memory says fixed ones may need doing).
Tank Catch
Tank prop rubber
Plus more SDOC, some parafin and some Halfords tar and bug remover.
I read the other day that you should polish chrome with a crumpled up ball of kitchen foil dipped in salt water. Some reaction fills in all the pits.
Has thanked: 1829 times
Been thanked: 1469 times
My two Ducatis have never really like the idea of damp - they seem to go orange quite quickly.
Why was it sitting in the corner , unloved?
Tricky
Has thanked: 2564 times
Been thanked: 2680 times
Post by Tricky »
crust wrote: Tue Jul 07, 2020 10:04 pm Took the front wheel and disks off to give them a proper clean.
Battery
Belts
Tank Catch
Tank prop rubber
Liking the look of this :thumbup:
P.S. you need to add " Pembrey TRC/RTTL trackday Sat 22nd August" to the to be ordered list ;)
Tricky wrote: Wed Jul 08, 2020 11:08 am
Battery
Belts
Tank Catch
Tank prop rubber
I hassled him on the phone this morning and for various reasons he doesn't think it's going to fly for Aug. Partly because of a possible trip away and partly because of time constraints for various bits needed. I get that... I think he's talking rubbish, but i get it :)
