Bike cleaning freaks
What you using these days to keep your bikes clean/protected?
I've been usuing SDoc100 for the last few years, but it seems to discolour exposed metal eventually. I have their maintenance kit with the colour restorer, polish and anti-corrosion spray. I'm not planning on riding in winter, but will more than likely opt for ACF 50 for protection/corrosion.
- Has thanked: 20876 times
- Been thanked: 13695 times
Re: Bike cleaning freaks
I bought Sdoc100 once but it's way too harsh on finishes especially, as you say, on polished metal surfaces. I tried the gtecnic orange clear or suchlike stuff but found that a bit ineffective? In the end I reverted to the old faithful paraffin. Most grime from the road is oil-based, and as oil is its own solvent, I also use the big cheap tins of Euro Car Parts maintenance spray (see link below) which makes wiping chain lube gunk and said residue off easy.
https://www.eurocarparts.com/p/triple-q ... -542770980
- Has thanked: 6125 times
- Been thanked: 15498 times
My 3 cleaning things are
GT-85
Muc-off pink bicycle cleaner
Autoglym tar remover.
If between the 3 of those it's not coming off, then it's not coming off.
Another great one that transforms bikes is 'trim gel' with a soft detailing sponge on all the black plastics, switchgear, hoses, casings etc... it's night and day better afterwards.
I'll be doing a run over with ACF-50 before the bike leaves the garage once it's delivered tomorrow.
GT-85
Aye - the last time I used the Sdoc I actually tipped some into a bucket of hot water to dilute it, which seems to have worked better. I'll give the maintenance spray a whirl.Taipan wrote: Wed Oct 20, 2021 9:58 am I bought Sdoc100 once but it's way too harsh on finishes especially, as you say, on polished metal surfaces. I tried the gtecnic orange clear or suchlike stuff but found that a bit ineffective? In the end I reverted to the old faithful paraffin. Most grime from the road is oil-based, and as oil is its own solvent, I also use the big cheap tins of Euro Car Parts maintenance spray (see link below) which makes wiping chain lube gunk and said residue off easy.
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
Cleaning?
Is that a thing?
Is that a thing?
I've become a fan of the Vulcanet wipes. Unless I'm caught out by a shitty road or rain,I've hardly used water since buying them to try.
Stupidly dear,mind. The Cheese would be code brown at the thought of it.
- Bigyin
- Has thanked: 1436 times
- Been thanked: 2738 times
I use cheap Tesco baby wipes....... does the job very well. For the tougher bits a degreaser like WD40 then a wipe, then a microfibre cloth to get rid of residue. I dont think the Multistrada has seen water for a wash and i blame Weeksy for that.Skub wrote: Wed Oct 20, 2021 10:06 pm I've become a fan of the Vulcanet wipes. Unless I'm caught out by a shitty road or rain,I've hardly used water since buying them to try.
The Fazer gets a bucket of soapy water over it every week or 2 as its the work bike. Its about to get its ACF50 layer for winter riding so the washing will decrease and it will look like a scrambler covered in shit soon
I think ACF has been one of the best products in recent years. If you want to slither about slimy roads in the cold,at least now your bike won't look like a complete bag of shite.
- Bigyin
I have been using it for years and it makes a huge difference. The first Multistrada did 3 winters commuting 70 miles a day back and forward in all weathers and despite being something that should melt at the first sign of water or cold managed snow, ice, road salt as long as the ACF was kept on top of and the bike rinsed down with cold water after a salty ride home. It got to almost 40000 miles before being written off but still looked half decent without rust everywhereSkub wrote: Wed Oct 20, 2021 10:15 pm I think ACF has been one of the best products in recent years. If you want to slither about slimy roads in the cold,at least now your bike won't look like a complete bag of shite.
ACF kept my SH300 in good order for many Winters,but the best thing ever is not having to ride on shitty salty roads.
- formula400
- Has thanked: 482 times
- Been thanked: 1045 times
- Contact:
how do you use the ACF stuff, and where does it go, seen it mentioned a lot.
CBR650r
- Bigyin
Comes in a spray can and use it on metal parts as its an aircraft anti corrosion spray. Dont get it on any perishable parts like tyres or on any brake components .... Basically puts a layer on the metal parts that protects them from corrosion and always looks wet. The dirt and crap sticks to it but doesnt penetrate it. Mine used to look like shit after 3-4 months of ACF and winter but once cleaned down looked goodformula400 wrote: Wed Oct 20, 2021 11:07 pm how do you use the ACF stuff, and where does it go, seen it mentioned a lot.
This is my first Multi on its second ACF winter spray
Hint: drop the spray tin in a bucket of hot water and let it warm up as it helps the spray mist more before applying
- formula400
- Contact:
ohhhh ok, looks fun, so just nuts and bolts and bits, might grab my self a tin for the MT
CBR650r
- Bigyin
All the engine too, swingarms and rear suspension components.formula400 wrote: Wed Oct 20, 2021 11:45 pm ohhhh ok, looks fun, so just nuts and bolts and bits, might grab my self a tin for the MT
As with everything there are You Tube vids for application as well as companies that will come, valet the bike and do the treatment for quite a bit more than the 15 quid spray can
Once its sprayed, run the engine till hot and it will smoke like buggery, its just the coating sorting itself
- wull
- Has thanked: 979 times
- Been thanked: 1858 times
weeksy wrote: Wed Oct 20, 2021 9:57 pm2018-01-19_09-45-25 by Steve Weeks, on Flickr
That had 8000 miles on the clocks.
Looks it
- Has thanked: 8045 times
- Been thanked: 5696 times
As I mentioned elsewhere, Bio-mex multi-surface cleaner (Amazon, Lakeland ~£14) got black spotty stuff off a lacquered, metallic finish car for me really easily when Autoglym tar remover had no effect. Like lots of detailing products I found at Halfords, it has white clay in so it's worth a try if all else fails. (If it doesn't work you can clean your stainless pans*, worktops, mirrors, sinks and baths with itweeksy wrote: Wed Oct 20, 2021 10:03 am My 3 cleaning things are
GT-85
* So it will almost certainly work on exhausts.
- Has thanked: 5964 times
- Been thanked: 3573 times
Used to use Sdoc100, then W5 Citrus wash but I found that could leave marks on the finish at times which was hard to get off. Currently I'm on Muc Off Nano stuff that was on special at SBS. You wet the bike first and then spray on. It's ok but not magic, but to be honest I do mine in sections with 2 buckets and dry off. GT85 if needs be on certain parts. I think mine looks clean enough for 14k.
What you use the GT85 for? I use to use it for lubing bicycle chains iirc.weeksy wrote: Wed Oct 20, 2021 10:03 am My 3 cleaning things are
GT-85
It's ace at cleaning stuff too, metal stuff mainly. It brings rear wheels up a treat as well as it'll cut through chain lube nicely. It'll clean motorcycle chains pretty well too.Hawkman wrote: Thu Oct 21, 2021 8:28 am
Also Mr Sheene is awesome too as a general polish.
