The Martian wrote: Tue Oct 12, 2021 10:34 pm
You sure the lamp (bulb) is going in properly? Often once in you have to turn them 1/4 turn so they click into the metal bits (that you can't see?)
If it's not a new fitting don't piss about, just replace it rather than risk it.
Definitely no clicking possible!!
But -
TightRS wrote: Wed Oct 13, 2021 1:42 am
It looks like there's a copper prong inside the slots, which can't reach the bulb to power it. The outer cover (diffuser) has copper tabs that insert into the holes whilst touching the bulb and complete the circuit
This is the right answer!! I am such a muppet!!
The inside of the cover looks like this - so yes, the connector is in the cover!!
When I looked at the other end (not sure it shows well in this pic) the copper was folded over
So I straightened it out and -
RISK OF FIRE/DEATH (just bin it lol):
If the cover is missing and you really had to, you could solder wire and spade terminals (or partly insulated strip of metal) to the ends of the bulb to insert it in the slots. Then put large pieces of heat shrink (or liquid/insulation tape) over the tube ends and exposed live metal parts.
I kinda think you are mean! But helpful! LOL I just wouldn't mess around with a bodge!!
I may be a bit of a muppet sometimes but I really do want to stay alive to enjoy my place, not fry myself in it
Well chuffed that the light now works. Kicking myself for buying a lamp I didn't sodding well need
LOL
