Leckrickery DIY help!!!
- Has thanked: 16210 times
- Been thanked: 3926 times
Ok, I wired in a light for the kitchen a while ago and it didn't work
So I bought a new bulb for it - still didn't work
Then I realised (somewhat late) that there are no metal bits where the bulb goes, so I'm guessing that's why it doesn't work
Sooo - do I have to bin the light unit or do you think I can buy the right bits??!!
Photo to show the bit where the bulb goes and I think there should be some kind of metal thingie there!! (And yes, I did fit it upsidedown -the switch is on the right when upside down!)
Re: Leckrickery DIY help!!!
Got a picture of the lamp? Does it have two legs on it that slot into the holes? Have you got the wires the right way round? Can you confirm power to the light unit. Not wired via another switch is it?
- Has thanked: 9828 times
- Been thanked: 10145 times
- Has thanked: 657 times
- Been thanked: 362 times
You sure the lamp (bulb) is going in properly? Often once in you have to turn them 1/4 turn so they click into the metal bits (that you can't see?)
If it's not a new fitting don't piss about, just replace it rather than risk it.
- Has thanked: 836 times
- Been thanked: 1239 times
I think the end caps are missing. I'm tempted to make a joke suggestion involving coat hangers but that's too risky.
Bin it and get a new fitting, they don't cost much and trying to bodge that will most likely end badly.
- Has thanked: 484 times
- Been thanked: 1427 times
Arse. She is down the south of France just before the hot bit. Closer to the equator so gravity works different dont it.
My thinking also. You chuck any odd looking bits away with the box. If this is a standard strip light it will have two pins sticking out each end that slit into a groove and twist into position like Martian is saying.
It looks like there's a copper prong inside the slots, which can't reach the bulb to power it. The outer cover (diffuser) has copper tabs that insert into the holes whilst touching the bulb and complete the circuit
It's probably so you don't get electrocuted by touching both ends of the tube as you insert it. Like this Spam
If you upgraded to an LED tube it might not work (polarity), until you flip it so each metal tip goes a different end of the holder.
RISK OF FIRE/DEATH (just bin it lol):
If the cover is missing and you really had to, you could solder wire and spade terminals (or partly insulated strip of metal) to the ends of the bulb to insert it in the slots. Then put large pieces of heat shrink (or liquid/insulation tape) over the tube ends and exposed live metal parts.
- Has thanked: 6377 times
- Been thanked: 4755 times
So it doesn't work without the diffuser in place? Now.....I wonder.....?
I know I'm daft, but even I wouldn't mess with bodging this!! LOL
Not new - it's one that someone took out of the bathroom here and I kept, just in case!! LOL
Definitely no clicking possible!!The Martian wrote: ↑Tue Oct 12, 2021 10:34 pm You sure the lamp (bulb) is going in properly? Often once in you have to turn them 1/4 turn so they click into the metal bits (that you can't see?)
But -
This is the right answer!! I am such a muppet!!
The inside of the cover looks like this - so yes, the connector is in the cover!!
When I looked at the other end (not sure it shows well in this pic) the copper was folded over
So I straightened it out and -
I kinda think you are mean! But helpful! LOL I just wouldn't mess around with a bodge!! I may be a bit of a muppet sometimes but I really do want to stay alive to enjoy my place, not fry myself in itTightRS wrote: ↑Wed Oct 13, 2021 1:42 am RISK OF FIRE/DEATH (just bin it lol):
Well chuffed that the light now works. Kicking myself for buying a lamp I didn't sodding well need LOL
Yay!
Thread needs a 'phew' emoticon.
- the_priest
- Has thanked: 1874 times
- Been thanked: 2170 times
A wee bit of trunking to cover those wires would definitely not go amiss.... please!? It really makes the ex IOSH Rospa H&S Manager in me scream and run around in little circles clucking maniacally... Not a pleasant sight, but better than you accidentally nick the live wire and fry the circuits. Get this stuff - cheap and works. https://smile.amazon.co.uk/D-Line-Decor ... 683&sr=8-6
