So @Couchy - when do we think the big day when we find out how fit/sick it is gonna be then?Tricky wrote: ↑Tue Jul 13, 2021 4:03 pmMy dyno-eye says it'll make approximately 54.371 hpCouchy wrote: ↑Tue Jul 13, 2021 3:43 pm Got the bike buttoned together for a dyno run soon. Oil and filter are fresh as is brake fluid and pads. Rear tyre is new and an 090 pro so just a front needed, gearing is already short too. Rides lovely at least in 1st and 2nd gear, so book is open for guesses on power ?
CRMC Project 400 super stock
- Tricky
- Has thanked: 2575 times
- Been thanked: 2695 times
Re: CRMC Project 400 super stock
- Has thanked: 326 times
- Been thanked: 2173 times
A day of battles today, chain tool broke popping new links off to make chain correct length. Then when that was done and chain on one of the adjusters was rounded. They’re weird on the NC23 as they screw into the swing arm and have a shouldered bolt and circlip arrangement. Took it off and wondered what to do, had the idea to stick the end in a lathe and turn it down, then smoothed the inside of a 6mm nut on the lathe and slid it on before having a grown up tig weld it on .
That was rear end done, with forks built they were fitted and discs dropped onto wheel, couldn’t get front axle in at all just wouldn’t run smooth through fork bottoms. Took forks out and noticed a rookie error, the damper rod bolt was the wrong one and poking into the axle hole a few thou. Back to the lathe and that was sorted and all bolted up.
Brakes next let’s see what fights me there
Classic bike Trackday on 24/9. I will dyno soon, only needs fuel tank on and wheeling over to exhaust man to make link pipe and fit a can so hopefully next couple weeksTricky wrote: ↑Wed Aug 04, 2021 10:36 amSo @Couchy - when do we think the big day when we find out how fit/sick it is gonna be then?Tricky wrote: ↑Tue Jul 13, 2021 4:03 pmMy dyno-eye says it'll make approximately 54.371 hpCouchy wrote: ↑Tue Jul 13, 2021 3:43 pm Got the bike buttoned together for a dyno run soon. Oil and filter are fresh as is brake fluid and pads. Rear tyre is new and an 090 pro so just a front needed, gearing is already short too. Rides lovely at least in 1st and 2nd gear, so book is open for guesses on power ?
Tank fitted, fairing on, brakes bled, new front tyre fitted, seat unit on and numerous other little jobs done. Mostly done when I have a few minutes spare at work. I’ll clean it up this week and get photos but it’s only an end can away from being done and I’ll drop it into unit next door to get that sorted
- Has thanked: 10301 times
- Been thanked: 6908 times
- Has thanked: 541 times
- Been thanked: 7563 times
I had a Tri-arm, it was my first big bike after passing my test.
I had it two days before a Nissan Sunny pulled out on me.
- Has thanked: 5460 times
- Been thanked: 13120 times
- Has thanked: 2250 times
- Been thanked: 1243 times
I had a tri-arm as my first big bike too, went under the rear wheels of a lorry on the north circularKungFooBob wrote: ↑Fri Sep 10, 2021 9:23 pm I had a Tri-arm, it was my first big bike after passing my test.
So cadwell park, wasn’t too confident as the loom although had some work was very poor but she ran so here we are. Took me a couple of sessions to get my head round lots of revs and being on a sportsbike. Luckily had a mate wirh me who races his NC30 so I just had to get my head down and ride. By the second session we were battling nicely and passing plenty in the inters group. The bike is great fun and handles and stops lovely. Third session though rev counter stopped but bike carried on working. Session after though all the electric fell out and started misfiring.
TBH happy I got 4 sessions and some proper battling.
Met up with pod70 who joined the fun on his cbr.
Plan, new loom needed, gearing needs to be slightly taller and I’ve got the proper seat unit to go on
- Has thanked: 65 times
- Been thanked: 1235 times
The only way you'll get 90hp out of a fzr4 is go put a 600 engine in there.Le_Fromage_Grande wrote: ↑Tue Jul 13, 2021 3:57 pm My guess is 55bhp, anything over 60 is good, apparently you can get 90 out of an FZR, but I think 70 is more realistic, and that takes a lot of money.
I worked on a full spec V & M sp motor for a couple of seasons, 73 was the best it gave, and we followed Moodie's bike onto the rollers which had different cams and that gave 74.
- Has thanked: 609 times
- Been thanked: 4130 times
I agree, low 70s is realistic, but I think it was BDK racing claimed they got 90. TBH you have to rev the knackers off it with the standard engine for it to moveDemannu wrote: ↑Mon Sep 27, 2021 8:40 amThe only way you'll get 90hp out of a fzr4 is go put a 600 engine in there.Le_Fromage_Grande wrote: ↑Tue Jul 13, 2021 3:57 pm My guess is 55bhp, anything over 60 is good, apparently you can get 90 out of an FZR, but I think 70 is more realistic, and that takes a lot of money.
