Smart Charger Recommendations
BartonBKing
- Has thanked: 2 times
- Been thanked: 41 times
My Optimate went faulty after 30 years so I bought an Oxford Oximiser 900. That lasted for about 2 years. Any recommendations before I splash out on a new Optimate? What you lot got? It’s constantly hooked up over winter to keep the battery maintained.
- Has thanked: 1926 times
- Been thanked: 1728 times
Re: Smart Charger Recommendations
I have a NoCo Genius one that I use - and can do both old fashioned and lithium batteries. Seems good
Nordboy
- Has thanked: 580 times
- Been thanked: 830 times
I tried an Optimate and whatever the oxford version was but they both broke. I've had my Ctek one for about 8 yrs now and ti works great. It's got modes as well so will do car and bike batteries. About £70 iirc but hugely outlasted the others.
- Has thanked: 12620 times
- Been thanked: 8541 times
- Been thanked: 15510 times
- dern
- Has thanked: 1187 times
- Been thanked: 2281 times
I’ve got two nocos and they’re superb. I have a four in one bolted to the garage wall and hook up everything to that.
I've had a CTEK XS5.0 for about 10 years and it's brilliant. Would be even better if it had a 6 volt option.....
Like most smart chargers it struggles a bit with a completely flat battery so I have an old school standard charger for those.
- MrLongbeard
- Has thanked: 780 times
- Been thanked: 3224 times
Oxford Oximiser 900 for the past 5 years, if it dies it'll be replaced with a Noco Genius 2x2
- Been thanked: 14171 times
I've used Optimate all year around for decades. Never had one break,so I've not tried anything else.
- Has thanked: 602 times
- Been thanked: 4529 times
- Has thanked: 2558 times
- Been thanked: 4168 times
Optimate/Accumate for me, but I run them off 24/7 timers which only activate the chargers for a couple of hours per week. I would imagine this lessens the likelihood of failure significantly. I prefer not to leave the battery on charge continuously, even at trickle charge levels.
- Has thanked: 8048 times
- Been thanked: 5698 times
On the subject of batteries, I was recently pondering the purchase of a battery analyser* and found a £99 one on Amazon. Anyone got any experience with such a thing?
* Didn't buy one as realistically, as with most toys, I'd use it a couple of times and it'd end up in a box in the garage and any vehicle battery failure I had would be sudden and catastrophic based on previous experience.
..... but I still like the idea of having one.
- Has thanked: 3650 times
- Been thanked: 2505 times
Spent many years testing Telecoms Lead Acid standby batteries using either Hioki or Yuasa testers ( about £2K). These would measure the batteries internal resistance in milliOhms and from this and the manufacturers info we would deduce whether the batteries were good, on their way out or totally Farked. This gave a pretty good indication of the batteries status but occasionally you'd find one that passed all the tests but folded in minutes when they were taken off charge.Count Steer wrote: Sun Jan 14, 2024 5:13 pm On the subject of batteries, I was recently pondering the purchase of a battery analyser* and found a £99 one on Amazon. Anyone got any experience with such a thing?
* Didn't buy one as realistically, as with most toys, I'd use it a couple of times and it'd end up in a box in the garage and any vehicle battery failure I had would be sudden and catastrophic based on previous experience...... but I still like the idea of having one.
- Has thanked: 2862 times
- Been thanked: 3518 times
I'd go for one that's simple to use and understand.
I don't think I've read a book on any Optimate,just plug it in and walk away.
- wull
- Has thanked: 979 times
- Been thanked: 1858 times
I have one of each but prefer my Noco plus I also use the Noco boost starter thingy majig which is brilliant, very compact but starts pretty much anything. I’ve been using it at work in the workshop.
A while ago I had a point to point battery drop tester(that I found in a vacated garage unit), and a yuasa battery tester that did a printed out report that did a print out report detailing the cca and load capacity. Niether helped when they batteries in my car died.Count Steer wrote: Sun Jan 14, 2024 5:13 pm On the subject of batteries, I was recently pondering the purchase of a battery analyser* and found a £99 one on Amazon. Anyone got any experience with such a thing?
mboy
- Has thanked: 855 times
- Been thanked: 696 times
CTEK MXS5.0
It has saved 3 batteries already now, paid for itself several times over.
Oxford Oximisers are notoriously shit. At best they don't properly charge higher capacity batteries, at worst they actually fail to charge batteries properly full stop. Avoid!!!
