Valve clearances time vs miles?
- dern
- Has thanked: 1027 times
- Been thanked: 1797 times
My assumption is that valve clearances don’t change over time, just miles. Is that correct? The bike I just bought has the valve clearances and rocker arms changed 2000 miles ago but 5 years ago. Leaving this and checking when it’s warmer but riding it in the meantime doesn’t seem like a high risk strategy… agreed?
Thanks
Mark
Thanks
Mark
- Has thanked: 5468 times
- Been thanked: 13167 times
- Has thanked: 10336 times
- Been thanked: 6915 times
- dern
Re: Valve clearances time vs miles?
That’s what I thought. I’ll change the oil and get using it. Cheers.
- Has thanked: 609 times
- Been thanked: 4133 times
The valve clearances tighten up because the valve springs stretch the valve stems, that doesn't happen when the engine isn't running, the the clearances get wider either the cams or the followers are wearing, again this only happens when the engine is running.
Wide clearances won't hurt the engine but you'll loose a small amount of power, tight valves will wreck an engine eventually.
- Has thanked: 255 times
- Been thanked: 143 times
Me being me I'd check them anyway as I'm sure it's not a tricky job. But they shouldn't have gone anywhere. Be good to have a look see what state the cam is in and see if there's any gravel and shit about
- Has thanked: 262 times
- Been thanked: 1278 times
- dern
- Has thanked: 65 times
- Been thanked: 1235 times
It's a KTM FFS.
The pixies will have been in there and changed EVERYTHING!
That certainly proves that they got some money.
If they did it at all, they probably did it wrong.
- Has thanked: 6239 times
- Been thanked: 5120 times
Are valve clearances like brake fluid, absorbing moisture over time?
- dern
- Has thanked: 218 times
- Been thanked: 689 times
I tried an Italian tune up to try and get rid of the condensation muck in the crankcases. Didn't work.
No, the heat drives the nasty off, they taste like a virgins bum.
Female yeah?
I wouldn’t want to get caught out again.
