Mechanical mayhem and woes... what you got.
Has thanked: 5449 times
Been thanked: 13084 times
My boss said "my brakes are not working properly"
ImageIMG_20231121_162046 by Steve Weeks, on Flickr
ImageIMG_20231121_162054 by Steve Weeks, on Flickr
ImageIMG_20231121_162105 by Steve Weeks, on Flickr
Has thanked: 9819 times
Been thanked: 10144 times
Re: Mechanical mayhem and woes... what you got.
Value for money. :thumbup:
If you don't count needing new discs.
formula400
Has thanked: 444 times
Been thanked: 863 times
Post by formula400 »
Better go check mine 😬😬😬
CBR650r :mrgreen:
Ditchfinder
Has thanked: 620 times
Been thanked: 692 times
Post by Ditchfinder »
That can happen to a set of pads in 1 ride round Rivi. Many a set of mine have shown similar amounts of wear before being binned :banana-wrench:
The wheel bearings in my e-bike rear wheel are wobbling like a fat man on a bouncy castle. They are a funny size so not easy to find an extractor or press for them. :angry-cussingblack:
So I have switched my saddle onto the wife's bike and pushed mine to the back of the shed until such time as I've cleared the bench of other jobs :king:
Has thanked: 6375 times
Been thanked: 4746 times
Give the boss a clip around the ear and remove the brake handles. :lol:
Been thanked: 2612 times
What are they from?
I used* to run my van pads until they made the wear limit warning noise. The most worn pad would be replaced until I had no spare pads left, then a set of new pads would be bought and fitted the next time the warning sound was heard. It was a half hour job on the Transit, I even did this one Boxing day morning a few years back, somewhere in the Forest of Dean.
*Used to because i haven't had this van long enough to create spare pads.
MTB.
I didn't know motor torpedo boats had brakes.
Has thanked: 2402 times
Been thanked: 3625 times
You've seen these pictures before, but this is what happens to pistons when you cut through the oil delivery pipe to the carb spigot on a 350LC...
Has thanked: 2550 times
Been thanked: 6241 times
weeksy wrote: Tue Nov 21, 2023 4:27 pm My boss said "my brakes are not working properly"
Your boss seems like they're very perceptive :thumbup:
mangocrazy wrote: Wed Nov 22, 2023 4:26 pm You've seen these pictures before, but this is what happens to pistons when you cut through the oil delivery pipe to the carb spigot on a 350LC...
That's feck all for an LC piston, I used to have a box of LC pistons with various sized holes in the crowns, I had a 250LC crack a piston right across the crown, down the sides to the gudgeon pin holes, I only noticed because it knocked about 5mph off the top speed and it rattled a little, I can't remember how long it was before I decided to take the head off to see if there was an engine issue, but it must have been a couple of weeks.
That's just the most recent example... Pride of place in my 'Hall of Shame' is a 350LC piston that I put a hole in halfway across Northern Spain in 1981. From cruising at 80-90mph it suddenly went Duuuuuuuh, slowed down and stopped. I pushed it to a garage where a mechanic removed the plugs , got a piece of welding rod and poked it down the plug holes. When the welding rod suddenly headed south the mechanic said 'Piston perforada'. I figured out the translation...
Has thanked: 1507 times
Been thanked: 1410 times
Le_Fromage_Grande wrote: Wed Nov 22, 2023 4:35 pm That's feck all for an LC piston, I used to have a box of LC pistons with various sized holes in the crowns, I had a 250LC crack a piston right across the crown, down the sides to the gudgeon pin holes, I only noticed because it knocked about 5mph off the top speed and it rattled a little, I can't remember how long it was before I decided to take the head off to see if there was an engine issue, but it must have been a couple of weeks.
Back when I ran a few Kaw triples I had a Rickman topbox under a bench that was full of fucked pistons.
Bowman
Has thanked: 161 times
Been thanked: 108 times
Post by Bowman »
Valve guide dropped into the chamber on the r1.
Heard the racket just after the back straight in Anglesey, coming out of rocket. I thought it was stones hitting the fairing, then it turned into a "clacking noise" and pulled off at Peel. Replacement engine time.
wheelnut
Has thanked: 905 times
Been thanked: 999 times
Post by wheelnut »
2021 Nissan navara.
EWL came on. Took it to main dealers. They had it for 3 weeks and replaced the EGR pump. EWL warning light came back on with 5 miles. Engine running fine, no other symptoms apart from the EWL.
Took it back. They had it another 3 weeks and announced that they didn’t know what the issue was and that they had authority from Nissan to put a new engine in. 😮
Had it another 9 weeks before I got it back. All that time they gave me an Enterprise rented car.
