Page 1 of 2
Removing an awkward nut...
Posted: Tue Nov 14, 2023 6:11 pm
by tricol
So, more stupid questions.
I'm attempting to fit my new Gilles risers. I need to remove the stock ones and to do that I need to undo the nut underneath the top fork yoke (x2). It's specced to 40nm. It's really tight for space. I can just about get my 14mm onto it square, but not much of an angle to turn it. Anyway, my first couple of attempts were futile. I've looked at a breaker bar, but I don't think I have the room to use one due to the chunkiness of the breaker bar end. The headstock and fork legs are very much in the way.
Before spending/wasting more money on this, should I just get a workshop to do it?
I f##kin hate spannering.
Re: Removing an awkward nut...
Posted: Tue Nov 14, 2023 6:12 pm
by Rockburner
Yes
Posted: Tue Nov 14, 2023 6:18 pm
by A_morti
Sounds like you're making it harder by taking the shortcut of not removing the top yoke. If you're not competent or not confident to do that then better bring it to a workshop.
Posted: Tue Nov 14, 2023 6:21 pm
by tricol
The Gilles manual doesn't state that the top yoke needs removed. I'll get in touch with Paddock tomorrow and see what they quote.
Posted: Tue Nov 14, 2023 6:28 pm
by ChrisW
Looks like you'd get in there with a long socket or perhaps a 3/8 bar. Can't imagine there's any need to remove the top yoke.
The still's from here if it helps:
Posted: Tue Nov 14, 2023 6:46 pm
by tricol
Thanks Chris. It's a standard ratchet bar, so not much leverage.
Posted: Tue Nov 14, 2023 6:56 pm
by mangocrazy
The area under the top yoke will be pretty crowded, so you might find that a long extension bar means you can get at the nut and the ratchet driver can operate in a much bigger arc. As long as there is line of sight from the ratchet to the nut, it doesn't matter how long the extension bar is. I bought a selection of different sized 'long' extension bars and they have been so useful.
These are the ones I bought:
https://www.ebay.co.uk/itm/403727890331
Posted: Tue Nov 14, 2023 7:00 pm
by tricol
I have short extension bars which make it easier. I can get the socket onto the nut nice and square, just can't budge the bugger.
Posted: Tue Nov 14, 2023 7:10 pm
by mangocrazy
You need a length of scaffold pole (or similar) to slip over the ratchet handle. Leverage is your friend, as Archimedes might have said...
Posted: Tue Nov 14, 2023 7:13 pm
by ChrisW
Give me a shout if you want to borrow any tools, I'm only in Nantwich.
Posted: Tue Nov 14, 2023 7:45 pm
by tricol
Thanks everyone. I'm only over in Congleton @ChrisW I'll see how I get on.
Posted: Tue Nov 14, 2023 7:59 pm
Ask the supplier. There may be a knack to it :)
Posted: Wed Nov 15, 2023 10:11 am
by tricol
Well I've managed to remove the air scoops from in front of the tank (thanks pop rivets) so that gives me loads more space to undo these nuts. I've also decided to go and get a 6pt socket for this nut as that will give me a better chance of removing these. All the sockets I have are 12 pt and more chance of rounding the nut as it's quite a bit of torque.
Posted: Wed Nov 15, 2023 10:16 am
by iansoady
I have a short wobbly extension as below which is very useful for this kind of thing. I also have a full universal joint but that tends to lock up.
Posted: Wed Nov 15, 2023 10:17 am
by tricol
I hope I will be fine now. A better socket with a breaker bar should work. Just down to me now.... *gulp*
I know this is trivial to many on here, but it's a big deal that I get this done myself.
Posted: Wed Nov 15, 2023 11:02 am
by Le_Fromage_Grande
Take the top yoke off, makes it much easier.
Posted: Fri Nov 17, 2023 9:05 am
by tricol
Success. New risers will be fitted today.
Posted: Fri Nov 17, 2023 9:57 am
by weeksy
tricol wrote: Fri Nov 17, 2023 9:05 am Success. New risers will be fitted today.
Tell us more.
Posted: Fri Nov 17, 2023 10:01 am
by tricol
I bought these: https://www.gillestooling.com/shop/hand ... -kit?c=185 from Calsport. Must say, they're beautifully made, really high quality, which you'd expect from Gilles. Fully adjustable, up to 24mm lower and roughly the same forward and backwards. Planning on running them as low as possible and a touch more forward.
Posted: Fri Nov 17, 2023 10:03 am
by weeksy
i meant about how you got the nut off :D
