Cleaning Brake Disks?
- Has thanked: 12620 times
- Been thanked: 8541 times
Been riding 46 years and never dreamt of cleaning disks. Always assumed the hard treatment they get would clean them.
But just lately the braking has lost it's edge. Changed pads but still same.
At Portimao the braking force wasn't always consistent. Just had to apply more pressure sometimes. I wasn't chasing lap times so let it go.
Just checked the front disks and they are covered in black crap. I thought the track use would have cleaned them ??
Anyway. What is this crap? Brake dust?
And best way to clean them? Taking wheel out tmrw to get new tyre fitted so will take the disks out. Can I soak them overnight in petrol?
- Been thanked: 15511 times
- Has thanked: 602 times
- Been thanked: 4529 times
Re: Cleaning Brake Disks?
Spray them with brake cleaner and wipe off with a clean rag or strong tissue roll
Because you might get it on the brakes?
That by definition is its job.
Spray onto a rag then wipe
- Has thanked: 2558 times
- Been thanked: 4169 times
About the only thing that the black deposits can be is old (probably burnt) pad material. You've been using them too hard!
When you get the new tyre fitted ask if there's anywhere that can bead blast the rotors.That's the best way to remove contaminants and it also leaves a good surface for pads to bed into. And if the pads are looking the slightest bit second hand get some new ones.
I'll whip them off and deglaze them as well.mangocrazy wrote: Fri Nov 10, 2023 4:24 pm About the only thing that the black deposits can be is old (probably burnt) pad material. You've been using them too hard!
- Been thanked: 14171 times
Handy gear for the garage,I use it for carb cleaning jets n' stuff,but not the rubber bits. It's an excellent degreaser.
Great for cleaning surfaces if you want to glue something.
A_morti
- Has thanked: 412 times
- Been thanked: 824 times
Shortly after I first got it, I realised the front brakes on my fz6 had not done well by doing only 10k miles in 20 years.
Like you, I wasn't keen on spraying a load of brake clean all around the bike. The more so because that's never going to get the drillings clean.
I took the front discs and pads off it, and brought them to the kitchen sink. Lots of elbow grease, dish soap, a variety of stiff brushes, and a nozzle brush for the drillings got them clean again, and the braking was much improved. I did give them a final wipe with some brake clean and a rag, but by then there really wasn't anything left to remove.
I'd go as far as to say you're wasting your time if you don't have a nozzle brush, as there's no other good way to clean out the drillings.
- Been thanked: 9505 times
If you've got a drill bit with the same (or very close) OD you could run that through them?
- Has thanked: 2862 times
- Been thanked: 3518 times
Yeah . I was thinking that.KungFooBob wrote: Fri Nov 10, 2023 7:57 pm If you've got a drill bit with the same (or very close) OD you could run that through them?
- Been thanked: 2730 times
You should reaming them to a consistent size, it'll mean the disc is dynamically balanced and the brakes will be smoother as a result.
- Has thanked: 2296 times
- Been thanked: 2684 times
Hex drive brass or steel wire brush, reversible drill, you might need 3 or 4 of the brushes, but they're cheap as chips.KungFooBob wrote: Fri Nov 10, 2023 7:57 pm If you've got a drill bit with the same (or very close) OD you could run that through them?
Surely you've got to do them as a pair to maintain the twin plane balance?cheb wrote: Fri Nov 10, 2023 8:49 pm You should reaming them to a consistent size, it'll mean the disc is dynamically balanced and the brakes will be smoother as a result.
I suspect David is right by the way, brake/clutch/carb cleaners are all just variations on the same volatile solvents.
10 points to skub too, thinking about proper cleaning before bonding
Probably convenience,the one can does lots of things. It's all kinda acetone isn't it?
Did that with wheel still in and got a lot of crap out. 95% of the shit is on the disk, so not too bothered about a tiny bit in the holes.KungFooBob wrote: Fri Nov 10, 2023 7:57 pm If you've got a drill bit with the same (or very close) OD you could run that through them?
I'll look for a drill wire brush later though.
