Socks.... What an exciting one :D
- Has thanked: 5503 times
- Been thanked: 12760 times
Over the years i've worn many a pair of Carnac socks. Used to be sold by a cycling company. Daft patterns but importantly they lasted really well.
They're mostly dead now and company seems to be no longer.. So need more socks. Requirements are as follows.
Calf length
Warm
Not too tight on ankles
Don't leave a load of 'bits' about
I'm struggling.... i know... it's exciting isn't it
I've got loads of socks but mostly they end up with really tight elastic on the calves and are uncomfortable. Or tiny trainer socks which are mostly bugger are use to anyone.
Calf length
Warm
- Potter
- Has thanked: 2216 times
- Been thanked: 4610 times
Re: Socks.... What an exciting one :D
You mean for normal daily wear?
I usually buy them from Next or Hugo Boss depending on which shop I’m nearest to when I need some.
They fit perfectly and last for ages.
- Has thanked: 2609 times
- Been thanked: 6012 times
I got an Oddballs pants+socks subscription for my birthday..
https://www.myoddballs.com/products/men ... ription-g2
- Trinity765
- Has thanked: 2420 times
- Been thanked: 2318 times
If you want warm, you need wool and with a bit of silk in the mix they'd be great (silk = v.warm).
I'd start here
https://www.johnlewis.com/search?search ... ks&chunk=2
I'd start here
Lockdown refugee
- Has thanked: 6263 times
- Been thanked: 4614 times
Falke do a range of cycling socks. Might be worth a look. Some look slimmer/more elastic around the calf than others. Key thing I've found with their activity socks is to try and get a pair where your feet are in the lower end of the size range ie if you're size 9 get socks for eg 9-11 range rather than eg 7-9. I got some for summer hiking and got it wrong...fortunately the missus is pleased with them as she's right at the lower end of their stated size range.
https://www.falke.com/uk_en/ts/falke-biking/men/
There's no other type of thing for me... day wear is cycling wear, is going out wear, is staying in wear... It's all the same sock. If i go out to pub i wear boots, so the socks can't be seen anyway
Smartwool socks are pretty good (same thing on sizing as I mentioned up there ^^^). Might not be long enough but if you have a Cotswold shop in the area they stock them so you could check them out. (They also have Oakley MTB socks but they're 100% synthetic - they're currently on sale at half price though...£10 iirc).
Actually heading off to our local Cotswold shop shortly...I'll have a look.
I feel your sock struggle! It's surprising how tricky it can be to find the perfect pair. I've had good luck with some hiking and outdoor brands for calf-length socks. They tend to be warm, durable, and usually not too tight.
- Potter
- Has thanked: 15604 times
- Been thanked: 9848 times
- Has thanked: 9680 times
- Been thanked: 9700 times
My fav walking socks are the Darn Tough boyos.
https://www.outdoorgb.com/p/Darn_Tough_ ... G8QAvD_BwE
- MrLongbeard
- Has thanked: 579 times
- Been thanked: 2289 times
What ever I get at Christmas does me, I don't wear socks in the house so they don't get much use either way
- Has thanked: 1788 times
- Been thanked: 1407 times
I used to like Pringle ones for every day - but the got bought by the Sock Shop , which is now a front for some extreme Chinese tat merchant.
In fact all the socks in TK Maxx and M&S seem to come from the same shoddy mills. They last about 3 months at the most.
I also have some Carnac /On One ones - they are good but don't last
I have some sealskinz ones that I hate with a passion - the make my feet colder.
The Woolly Boolly ones are good
I bought M&S socks for years but, like their shoes, they've gone down the tubes. (It may surprise some but their shoes actually used to be pretty good!).Mr Moofo wrote: ↑Fri Oct 20, 2023 6:52 pm I used to like Pringle ones for every day - but the got bought by the Sock Shop , which is now a front for some extreme Chinese tat merchant.
- Been thanked: 2499 times
M&S stopped doing 100% black cotton socks years ago. Socks are the only thing I buy from Amazon, I can't find anywhere that sells them at reasonable prices. I tend to shred them because I wear slightly loose work boots and have rough feet.
There's boring.
There's boring.
- gremlin
- Has thanked: 776 times
- Been thanked: 4514 times
If testicular comfort is your goal:
https://www.urbansurfer.co.uk/saxx-m87
Saxx undercrackers.
(I know this is all about sockage, but it's underwear related)
Saxx undercrackers.
Not boring at all to the average sockist. Folk don't pay enough attention to socks. They're quite complicated things. Most of us could knock up some sort of body covering approximating to a pair of pants and a t-shirt but they'd have to wind strips of fabric around their feet to approximate to a sock.
Spawn the elder takes commissions to knit socks. They know more about knitting, crochet and weaving than is usual.
Separate toed socks for the win, especially when worn with sandals, in a Roman soldier stylee.
- Has thanked: 532 times
- Been thanked: 7217 times
