MTB parts for sale
Has thanked: 3644 times
Been thanked: 2502 times
MTB parts for sale
2016 Fox 36's, 160mm travel, 29er, steerer cut to 170mm, non boost. PUSH Coil conversion fitted with two springs, green or blue covering weights 160-210lbs. £250
2015 Specialized Enduro Expert 29er frame, carbon front triangle and alloy rear triangle. Size M. Upgraded Fox X2 fitted to replace the dire Cane Creek shock it was supplied with. Invisiframed from new, some rub marks on the rear triangle and a few marks in the invisframe. 155mm travel. Comes with headset, no BB. Also supplied with Bike Yoke adapter if you want to fit a coil shock.
£250
Has thanked: 1926 times
Been thanked: 1728 times
Re: MTB parts for sale
the Enduro is going !
I thought everyone in Frustum rode an Enduro!
Mr Moofo wrote: Fri Jul 14, 2023 5:06 pm the Enduro is going !
It's either the Steel is Real Hardtail snob or the E-Bike Wanka from now on. Though the IBIS USA the shop had was drool worthy but at £12K for the limited edition version it can stay there.......
