I’ve managed to snap the securing tab from inside an RJ45 socket on a device (Amazon FireStick Ethernet adapter) through a combination of clumsiness on my part and those bloody hard plastic “wings” on moulded RJ45 patch leads.
My planned fix is glueing in a patch lead into the socket as a permanent fly lead.
There is a little wiggle room in the socket so whatever glue needs to have a degree of gap filling properties and also hold the plug in to maintain the connections and also be non-conductive should it come into contact with the pins.
So what say you?
Which glue would you use?
- Has thanked: 836 times
- Been thanked: 1238 times
Re: Which glue would you use?
Just use some duct tape round the device and the cable, it won't be pretty but it will work.
- Has thanked: 2550 times
- Been thanked: 6241 times
Can't you wedge it with a match stick or something? Seems a bit less drastic.
- Been thanked: 7526 times
If it's for networking it needs to conform to RFC8140 or maybe RFC4824.
