Change device ip range?
- Has thanked: 316 times
- Been thanked: 1078 times
I need to change the IP address of my laptop (currently in 192.168.1.x range) to within the same range as my cctv cameras (192.168.254.x range) so I can change them into the same range as the router (192.168.1.x).
The reason for this is it impractical to extend all of the network cabling to allow us to move the NVR to another room and the nvr allows cameras to be remotely added via a separate Poe switch.
Is this simply a case of connecting the laptop to the home network via Ethernet and manually setting the laptop ip address to within the correct range?
Or is there a better way?
- Been thanked: 15510 times
Re: Change device ip range?
well that's a question. if it works and connects to the internet et on 192.168.1.* then that's goof.
But who's configured the 192.168.254 range....
That range may not be configured to see outside... So your laptop will only be able to see the cameras... nothing else. If all you need is that, then that's fine and good...
What you're looking to do is perfectly fine.... but you need to know the Subnet Mask and default gateway settings too. If your 254 network is DHCP enabled, as soon as you connect the laptop it'll get an IP address from DHCP which will also include these.
Go to a command prompt and type ipconfig (then enter)
If it doesnt, then you'll need to know these... you'll also need to know the address you pick isn't being used by anything else.
go to a command prompt and type ping 192.168.254.* and it'll come back with a reply, or request timed out..
Configure it with one that's request timed out.
The NVR has set the cameras to its “internal” ip range of 192.168.254.* and I’m guessing it has a default gateway of 192.168.254.1 as the available range starts at 192.168.254.2 The NVR is dchp enabled so I’ll plug the laptop straight into that and give it a go
As soon as the cameras as switched into the correct range, I’ll have no need to access the NVR range again as future cameras can be configured into the correct range straight out of the box.
Thanks
Thanks
you can't guess
DG and SM settings need to be exact.... your assumption of 254.1 is fairly likely.... but still... you can't guess
Subnet is definitely 255.255.255.0 as the software to change the camera ip address reports that but doesn’t show the default gateway. I’m pretty sure the NVR user interface shows all of the settings.
I assume dchp should take care of those anyway
- Has thanked: 602 times
- Been thanked: 4529 times
Are the cameras on the same physical network or vlan as the 192.168.1.0/24 network?
Hikvision have an app, SADP tool which allows you to find their devices anywhere on the network, the tool reports the NVR and one camera in the 192.168.1 range. This camera has never been connected to the NVR via ‘plug and play’ and worked with the NVR remotely (ie plugged in via a separate POE switch on the 192.168.1 LAN
The other four cameras were added to the NVR fresh out of the box via “plug and play” and worked seamlessly, all in the NVR ip range of 192.168.254
I’m saying worked as I had to carry out a factory reset on the NVR yesterday as I’d lost the admin password and now I can’t see any cameras FFS! Ordinarily I’d just do a factory reset on the cameras but the two I can physically reach don’t appear to have a reset button on them….!
- wheelnut
- Has thanked: 929 times
- Been thanked: 918 times
If you change the range on the cameras you’ll need to change it on the dvr as well otherwise they won’t be able to talk to each other.Silly Car wrote: Fri Apr 14, 2023 6:44 am The NVR has set the cameras to its “internal” ip range of 192.168.254.* and I’m guessing it has a default gateway of 192.168.254.1 as the available range starts at 192.168.254.2 The NVR is dchp enabled so I’ll plug the laptop straight into that and give it a go
Thanks
Bring the dvr and cameras into the same 192.168.1.x range as the rest of the home network but you’ll need to switch off dhcp on the dvr.
- wheelnut
I suspect after the reset the dvr has gone back to the default IP (probably 192.168.1.something) and some of the cameras are stuck on the .254. Switch them off and on again at the Poe switch and they should pick up the new ip from the dvr and then see where you want to go from there.Silly Car wrote: Fri Apr 14, 2023 8:07 am Hikvision have an app, SADP tool which allows you to find their devices anywhere on the network, the tool reports the NVR and one camera in the 192.168.1 range. This camera has never been connected to the NVR via ‘plug and play’ and worked with the NVR remotely (ie plugged in via a separate POE switch on the 192.168.1 LAN
That would be the common sense approach, ip addresses appear to be locked on the cameras and even though I can ping them and open their browser page, I can’t log in as I don’t know, and can’t find, the username & passwords…wheelnut wrote: Fri Apr 14, 2023 8:21 amI suspect after the reset the dvr has gone back to the default IP (probably 192.168.1.something) and some of the cameras are stuck on the .254. Switch them off and on again at the Poe switch and they should pick up the new ip from the dvr and then see where you want to go from there.Silly Car wrote: Fri Apr 14, 2023 8:07 am Hikvision have an app, SADP tool which allows you to find their devices anywhere on the network, the tool reports the NVR and one camera in the 192.168.1 range. This camera has never been connected to the NVR via ‘plug and play’ and worked with the NVR remotely (ie plugged in via a separate POE switch on the 192.168.1 LAN
- wheelnut
If you Google the make and model of the dvr you should be able to find the default login/pw and IP it will be in the paperwork you got with it (which you should find online as well).
Default passwords didn’t work either.
Thankfully, Hikvision UK tech support are on the case and we have one camera back on line via the Poe switch, just 3 more to go…
- Has thanked: 8048 times
- Been thanked: 5698 times
They're probably fixing it remotely from their Chinese data centre.Silly Car wrote: Fri Apr 14, 2023 12:05 pm Default passwords didn’t work either.
They are more than welcome to watch the squirrels shagging in the trees if they wishCount Steer wrote: Fri Apr 14, 2023 1:03 pmThey're probably fixing it remotely from their Chinese data centre.Silly Car wrote: Fri Apr 14, 2023 12:05 pm Default passwords didn’t work either.
Thankfully, Hikvision UK tech support are on the case and we have one camera back on line via the Poe switch, just 3 more to go…![]()
And inevitably…
I’ve had to change the cameras back to the original “internal” ip range of the NVR as the cameras were gobbling up the LAN bandwidth and I was getting complaints from the Doris that her streaming was being impacted.
Thankfully, I will still be able to relocate the NVR as it is possible to plug the cameras directly into the POE switch and then connect that to one of the POE ports on the NVR, I just need to either run a cable from point A to B, or can set up a separate WI-FI network to run on the 192.168.254 ip range reserving the 192.168.1 range for non-cctv traffic.
A cable is my preferred option given the 9” walls and distance involved, thankfully, there are two redundant RJ45 sockets on the same floor as my office which I can repurpose to provide access to both LANs in my home office even if it means moving two wardrobes and lifting a few floorboards
Home CCTV system, there were a spate of thefts / petty vandalism in the area a while back so I installed cameras around the outside to deter ne’er dowells which seems to have worked* Neighbours did the same so you can’t enter the street without being spotted.
They record 24-7 so use a lot of bandwidth which has never been noticed as they’ve run on their own network.
* the other reason crime has gone down is one such scrote happened to attempt to break into the ‘wrong’ persons car in a neighbouring area, got chased into our street and promptly received some ‘restorative justice’. Strangely, the crime rate has since gone down…
