Cutting up veg
Anything from pizza to pasta, from steak to cake.
Has thanked: 833 times
Been thanked: 1237 times
Cutting up veg
I'd like to find a motorised device that chops up salad and veg without pulverising them.
This is for someone who can't use a knife easily, mandolines are out bacause we are too far away from the nearest hospital.
All the chopping aids I look at have photos of them full of neatly chopped veg to the size I want but clearly weren't cut up by that machine. I've seen professional kitchen stuff that does what I want, is there anything for the domestic market that doesn't cost much more than £100 and doesn't need 2' of counter space?
I'm looking for something that does this, the reviews say this doesn't produce what the photo shows.
https://ninjakitchen.co.uk/product/ninj ... 89c266f492
Has thanked: 484 times
Been thanked: 1427 times
Re: Cutting up veg
Bang, bang, bang, bang, check. Bang, bang, bang, bang, check. Bang, bang, bang, bang, check. Bang, bang, bang, bang, check. Kind of thing
Re: Cutting up veg
That would probably do it but I'm looking for something that doesn't involve such a workout, there are loads of slicers and pulverisers around but not much seems to be able to dice no matter how many of them have marketing photos of them full of perfectly diced fruit & veg.
This looks good for the job but is a little spendy at £500.
https://www.bbcgoodfood.com/review/sage ... -peel-dice
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Re: Cutting up veg
Post by Screwdriver »
Mussels wrote: Mon Apr 03, 2023 1:35 pm I'd like to find a motorised device that chops up salad and veg without pulverising them.
How about something like a paper guillotine but with a knife edge? I could design and make one.
It wouldn't be motorised (!) but with a long handle and constrained blade motion, a person with limited mobility could safely use it.
Plato
Re: Cutting up veg
Thanks for the offer but I do most of the cooking anyway so it wouldn't get enough use to be worth it, that's where I'm at with the expensive thing above (as well as it not being dishwasher safe).
I was hoping someone would recommend one they have that does a great job and I'd get use out of as well, I think unfortunately what I want doesn't quite exist.
Screwdriver
Re: Cutting up veg
Mussels wrote: Wed Apr 05, 2023 12:04 am ...I think unfortunately what I want doesn't quite exist.
Yes, I think I just said that.
I might make one anyway. :hmmm:
Plato
Has thanked: 2549 times
Been thanked: 2285 times
Re: Cutting up veg
Mussels wrote: Wed Apr 05, 2023 12:04 am Thanks for the offer but I do most of the cooking anyway so it wouldn't get enough use to be worth it, that's where I'm at with the expensive thing above (as well as it not being dishwasher safe).
IIRC my Mum had something that might help, made by a French company, Moulinex or something like that.
It was basically a vertical mill with assorted blade, you opened up it's folding legs to stabilize it, chose your blade, dropped the veg in a small hopper, closed a lid to push them down (and to keep your fingers safe) and then turned a rotary handle. Chips or slices of veg came out the bottom. As I recall it it got used to chip up potatoes and swede for pasty making, but I think it had 3 or 4 blades for different sizes of bits. They probably make an electric version today.
Has thanked: 6374 times
Been thanked: 4745 times
Re: Cutting up veg
There was a thing called an 'autochop' possibly made by Zyliss back in the 70s? They were utterly rubbish!
It's quite a difficult process to automate for a range of veg. Probably needs a 2 stage process with adjustable blades if you want regular, uniform sized bits of different shaped ingredients (probably why good ones are chunky and expensive).
(There was a whole course dedicated to this sort of thing at uni - covered a bit more than veg though. One of the problems they were set was to sort ripe and unripe tomatoes - non-destructivley - as part of a high throughput process. The range of solutions students came up with, compared to the actual method usually used*, was hilarious).
*Incredibly simple, no moving parts apart from the conveyor/tomatoes.
Ant
Has thanked: 39 times
Been thanked: 227 times
Re: Cutting up veg
Post by Ant »
I've got a Tefal Fresh Express, love it.
Has thanked: 2550 times
Been thanked: 6238 times
Re: Cutting up veg
Count Steer wrote: Wed Apr 05, 2023 10:28 am *Incredibly simple, no moving parts apart from the conveyor/tomatoes.
Minimum wage Polish immigrant?
Re: Cutting up veg
Mr. Dazzle wrote: Thu Apr 06, 2023 6:34 pm
Possibly watching in case something went wrong...but no, the tomatoes dropped a very short distance off the belt onto a slope with a small ridge across. The firm ones bounce over without bruising. (I think the slope tilted sideways so the others rolled off at 90°). Something like that anyway.
The blokes (it was all blokes) on the Industrial Engineering course came up with complicated things that checked the colour, gently prodded or squeezed them etc etc etc.
Has thanked: 15937 times
Been thanked: 10241 times
Re: Cutting up veg
:thumbup:
