Would it be too much.....
Demannu
Has thanked: 65 times
Been thanked: 1234 times
Post by Demannu »
.........If my brake lines colour matched the bike.
Going to replace the 6yo lines with some braided hose, and as I have a 60th anniversary Yamaha, was thinking about yellow lines with black fittings.
A tad gauche, or befitting of a tart's handbag?
wull
Has thanked: 979 times
Been thanked: 1858 times
Re: Would it be too much.....
Post by wull »
So long as you don’t touch the levers and bar ends you’re fine
Post a pic of the bike!
Taipan's the man to ask :D
Tarts handbag, but go for it, if you like it why worry about what other people think.
Personally I'd take some convincing that either black or clear isn't the way to go.
It's a bit like tyre lettering paint.....
Mind you,I'm quite partial to a bit of rimming tape,so my tastes may be slightly suspect.
Demannu
Post by Demannu »
KungFooBob wrote: Sun Feb 19, 2023 7:19 am Post a pic of the bike!
Pass the rimming hat.....
Looking at the pic, I'd personally say no, but if you can get the right shade of yellow it might not look too bad.
Demannu
Post by Demannu »
KungFooBob wrote: Sun Feb 19, 2023 2:48 pm Looking at the pic, I'd personally say no, but if you can get the right shade of yellow it might not look too bad.
Says the man who watches Corrie! 🤠
Demannu wrote: Sun Feb 19, 2023 3:01 pm
Phew, I thought you were going to mention the Pink GSXR :p
Has thanked: 2556 times
Been thanked: 4167 times
I'd say yes. The bike is predominantly black apart from the tank, so a yellow accent with braided lines should work. But get two lines from the master cylinder, not that daft hoop over the mudguard arrangement that manufacturers love.
Demannu
Post by Demannu »
mangocrazy wrote: Sun Feb 19, 2023 3:07 pm I'd say yes. The bike is predominantly black apart from the tank, so a yellow accent with braided lines should work. But get two lines from the master cylinder, not that daft hoop over the mudguard arrangement that manufacturers love.
Unfortunately it has abs, so there is only a single feed to the front brakes, hence the 'hoop'.
I suppose I could run to a splitter, then single lines to each caliper, but that would mean custom lines, which adds to the price, and another union, and somewhere to mount the splitter..........
Ah yes, ABS. Had forgotten about that.
Yorick wrote: Sun Feb 19, 2023 8:10 am Taipan's the man to ask :D
Is it? My answer would be no, no and thrice no!
