Morning All!
Not a great deal to report on this in terms of updates, but a couple of things for you to cast your eyes over......
Noticed that the RGV Was dropping a bit of oil, something that started off as minuscule - But has gradually increased over the last 6 Weeks or so. from the colour of the oil, it looked to be 2T - So first suspicions laid with the Autolube Pump.
Awkwardly, The pump sits just to the right and behind the front sprocket pretty much meaning lots of fun trying to work on it with a fully assembled bike:
So spent some time checking the feed coming into the pump, replacing all of the compression fittings on the lines out of the pump and putting fresh PTFE Tape on the bleed screw (Fibre Washers for this are no longer available in this size unless you purchase hundreds) and reassembled everything and span it up again to get the oil flowing.
Next day I was greeted by another tiny pool of oil
All the connections were good, and I could not for the life of me work out where this little drip that was hanging off the bottom corner of the pump was coming from, Every connection I checked was dry.
Looking through the workshop manual however the penny dropped. Where the pump is driven from the gearbox, there is a drive and a bush. There is no oil seal on the shaft and it uses the oil from the gearbox to keep the shaft, bush and connection to the pump lubed. The only thing keeping the gearbox oil in is a paper gaskett between the crank case and the autolube pump body.
As the gearbox oil is red too, I just assumed it was 2T Oil
Didn't expect the way it was sealed to be like this to be honest, but as I have said before during this project I am learning all the time!
So new Gasket (£2 Delivered from Flea Bay - Suzuki wanted £9) and a sparing amount of sealant and we are now oil tight.
Other than that I have new silencers on now, I cannot afford to replace the entire system at present so purchased one of the very few kits out there for the OEM Pipes. Only changed I have made to the kit is to paint the connector fittings black to match the rest of the system and pleased with the results.
Panels go for paint in two weeks time - Think we are looking at a lead time of a month or so. Just in time for it to be locked in the garage for the next 6 Months
