Pinky gets a partial strip down.
Gregor
Has thanked: 1756 times
Been thanked: 1153 times
Post by Gregor »
Since getting the little KDX in the summer I’ve put 600kms on the clock.
It’s turned out to be in excellent nick for its 31 years, the only issues were the low gearing which meant being very gentle with the throttle or the front wheel was up. Sorted this with a 44 rear sprocket. In the heat of summer after about 1/2 an hours riding I was getting some surging coming off the throttle but before I could pull the carb off temps dropped and its fueling nicely now.
After a couple of wet rides I thought I’d check out the state of things under the plastic.
The rear sub frame was looking a little rusty.
The frame lock stop at some point has been ground down, too far on one side it turns out, the fork top tube is making contact with the frame!
The expansion pipe will probably need a decoke and the silencer repacked.
Rear brake calliper needs a clean up.
Speedo drive cable snapped recently.
Not wanting to freeze my tits off in the garage I’ve taken the bike down into the cellar where it’s a balmy 13 deg all year round and the lighting is better.
Re: Pinky gets a partial strip down.
Weirdly i thought you'd ridden a lot more on it.
Gregor
Post by Gregor »
The subframe isn’t as rusty as I expected, I’ll treat the exposed metal with Kurust and leave it until I’ve got enough parts to make a trip to the powdercoaters worthwile.
Gregor
Post by Gregor »
weeksy wrote: Wed Nov 30, 2022 1:27 pm Weirdly i thought you'd ridden a lot more on it.
It’s the one I ride the most these days but usually an hour or so on the local greenlanes or back lanes once a week.
Demannu
Has thanked: 65 times
Been thanked: 1234 times
Post by Demannu »
What's the state of the unitrak linkage bearings?
Getting the bike down stairs is easy.
HTF do you get it up them?
Gregor
Post by Gregor »
Demannu wrote: Wed Nov 30, 2022 4:52 pm What's the state of the unitrak linkage bearings?
Not got that far yet, the shock could probably do with a service.
What I like is that frame rail that unbolts to drop the airbox out of the way.
Gregor
Post by Gregor »
Yorick wrote: Wed Nov 30, 2022 4:57 pm Getting the bike down stairs is easy.
A rope, a strap and a Toyota Yaris :P
