Specialized Sworks Enduro. £2000
Has thanked: 5449 times
Been thanked: 13085 times
https://www.ebay.co.uk/itm/275186676795
Up for grabs is my lads 2016 Sworks Enduro. This was £6000 new and is a 13.1kg Enduro killing machine.
This bike was raced in EWS by Abigale Lawton, who sold the bike to my lad. (well, me actually)
We've owned it for 18 months but he's now outgrowing it as teenagers do and it's time to pass it on. It has a couple of tiny stone chips but is lovely apart from that.
I look after the bike and it's 100% perfect. Every bearing is smooth, pivot, linkage, shock mounts, headset etc.
Shock was recently serviced at Sprung Suspension as was the Forks, invoices can be provided, both were done this Dec/Jan.
The bike wants for nothing and his hands has been placing 4th/5th in local races... but sadly it's time to let it go
If you're after a fast ripping trail bike, light, fast and effective, it's really the best, the Sworks has a proven geometry and heritage for a good reason.
https://www.specializedconceptstore.co. ... duro-650b/
Spec is below.
There's all mountain riding, and then there's getting rowdy over the entire mountain. And when it comes to a playful ride quality over difficult terrain, nothing beats our S-Works Enduro FSR 650b. To keep the weight down, the frame is constructed from our top-tier FACT IS-X 11m carbon fibre. This material comes with the added benefit of being incredibly stiff, which is balanced out by our 650b Geometry's roomy top tube, short chainstays, slack head tube, and longer wheelbase. Add it all up, and you get a lively ride thats incredibly responsive on both climbs and descents. And to further ensure top-level performance on the way down, this geo is mated with 160mm of plush travel up front and 165mm at rear. Handling suspension duties out back is the revolutionary hlins single tube rear shock. And for the build, the Enduro spares no expense at hitting the pinnacle of performance, with a full SRAM XX1 groupset, powerful Guide RS Carbon brakes, hand-built carbon Roval wheels, and our all-new Command Post IRcc with up to 10 middle positions. Make the mountain bend to you.
FRAME FACT IS-X 11m carbon, 650b geometry, FACT carbon front triangle, M5 rear triangle, tapered head tube, PF30 BB, internal Command Post IR routing, 142mm dropouts, full cartridge bearing pivots, replaceable derailleur hanger, 165mm travel
REAR SHOCK Rockshox Monarch R, running a 210*55 and a BikeYoke kit to allow standard metric shocks.
FORK RockShox Pike RCT3 650b, Solo Air spring, 160mm travel, 2-stage compression adjust, rebound adjust, tapered steerer, 42mm offset, 15mm Maxle Ultimate thru-axle
HEADSET 1-1/8" upper, 1-1/2" lower, threadless, Campy style, cartridge bearings
STEM Syntace MegaForce, 6-degree rise
HANDLEBARS S-Works DH, carbon, 8-degree backsweep, 6-degree upsweep, 780mm, 31.8mm
GRIPS Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, L/XL: XL thickness
FRONT BRAKE SRAM Guide RS Carbon, metallic pads, 200m Centreline rotor
REAR BRAKE SRAM Guide RS Carbon, metallic pads, 180mm Centreline rotor
BRAKE LEVERS SRAM Guide RS Carbon, carbon lever, reach adjust, cartridge bearing lever pivot
REAR DERAILLEUR SRAM GX, 11-speed
SHIFT LEVERS SRAM GX, 11-speed, trigger
CASSETTE SRAM XX1, 11-speed, 10-42t
CHAIN SRAM PC-XX1, 11-speed, w/ PowerLink
CRANKSET S-Works, FACT carbon, 30T X-Sync ring, 104mm BCD spider
CHAINRINGS 30T, w/ Specialized Mini-Guide
BOTTOM BRACKET SRAM, PF30, OS press-in bearings, sealed cartridge
PEDALS N/A
RIMS Roval Traverse SL 650b, carbon, disc, 30mm inner width, 24/28h
FRONT HUB Easton ARC 27, 15mm thru-axle,
REAR HUB Easton ARC 27 142, 54t engagement, SRAM XX1 XD driver body,
SPOKES DT Swiss Revolution
FRONT TYRE Maxxis Shorty DH compound, folding bead, 650bx2.5"
REAR TYRE Specialized Butcher Grid, 60TPI, 2Bliss Ready, folding bead, 650bx2.3"
INNER TUBES Standard, Presta valve
SADDLE Body Charge Spoon
SEATPOST Command Post IRcc, cruiser control technology, micro-adjust height adjustable, alien head design, bottom mount cable routing, remote adjust SRL lever, 30.9mm, S: 100mm travel, M/L/XL: 125mm
SEAT BINDER Specialized, 7050 alloy, single bolt, 34.9mm
Re: Specialized Sworks Enduro. £2000
Sold pending collection
