How do I make it quieter?
Dickyboy
Has thanked: 485 times
Been thanked: 343 times
Post by Dickyboy »
So I've got this Guzzi 1200 sport which came with fancy high level but loud exhausts like this
https://www.topspeed.com/motorcycles/mo ... tml#244814
they are straight through with no baffles and set the neighbours van alarm off, so for now I've returned it to standard 🙁 any ideas how to make the fancy ones quieter?
Trinity765
Has thanked: 2442 times
Been thanked: 2398 times
Re: How do I make it quieter?
Post by Trinity765 »
Put a pillow behind the headboard?
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Post by DefTrap »
You can buy rudimentary baffles (a bolt in tube with holes) which take the edge off. Any more than that will be the same but with a bit of wadding and then you'll no doubt have to fiddle with jetting.
Bear in mind I fiddle with rat bikes and yours looks nice, so you might want to take it to someone who know what they're doing, but the principal is the same.
Has thanked: 2550 times
Been thanked: 6244 times
Stand further away! Riding may be difficult though, I grant you.
In all seriousness though, can you open them up? I can't tell from the pics, but presumably they're riveted together. Making them quieter is gonna involve putting something inside so first you gotta get inside....
Has thanked: 9819 times
Been thanked: 10144 times
DB killers up the wazoo?
What size pipes are they, I might have some baffles knocking about, though I found they messed the throttle response up when I've tried them in the past.
If the pipes are linked you could put a baffle in one pipe.
Has thanked: 15949 times
Been thanked: 10243 times
IME the baffles you can see through don't help quite things down much, They need to blanked off at the end of the tube to make any sort of difference.
Dickyboy
Post by Dickyboy »
Fabricator has suggested making up oval to round adaptors and getting a couple of dB killers but outlets are 45mm x 65mm oval and sticking a couple of 45mm dia dB killers are gonna cut off a fair amount, I guess I could just drill & bolt some dB killers in there & leave the gaps open but..
1. Will that achieve anything
2. Which dB killers to choose
You can get these ones that go in the other end of the can.
https://tinyurl.com/cwdh4jmh
Alan PBTD
Has thanked: 6 times
Been thanked: 209 times
Post by Alan PBTD »
Taipan wrote: Tue Feb 01, 2022 9:34 pm https://tinyurl.com/cwdh4jmh
Are about as much use as a chocolate teapot. Have a chat with Mark Holland @ http://www.mhpexhaust.co.uk/ and or https://www.pipewerx.co.uk/ as they are both regarded as the silencer specialists. Mark will make you some pipe work that will work with the engine @ the DB limit you want and probably make the extra silencer removable for when next doors away. Both will do them in a choice of finishes - carbon / Chrome / Stainless etc.
Pgm
Been thanked: 83 times
Post by Pgm »
Alan PBTD wrote: Tue Feb 01, 2022 10:06 pm
I’ve used MHP Mark Hill a fair bit over the years and like his work but you do have to be patient as the wait to get anything done can be rather long.
Ditchfinder
Has thanked: 620 times
Been thanked: 692 times
Post by Ditchfinder »
Might also be worth posting here:https://www.grisoghetto.com There's a couple of guys in Oz on there who know lots about fuelling and exhausts of most Guzzis.
A chap called Beetle on there writes maps for Griso's and the like so should be able to give you some pointers. Or you can FB him https://www.facebook.com/Beetlemaps-654327421440868/
Dickyboy
Post by Dickyboy »
Yeah, I've read a few reviews & don't fancy going down that path, unless I was nearby.
@ditchfinder - I've got a beetle map on it with std pipes on it at the moment & have previously had a my16 ecu from cliff in oz on my Centauro. So far Baldrick seems the most knowledgeable on these particular pipes but I just want them a bit quieter, will take them to a local exhaust fab guy I know & see what he can suggest. Ta
Has thanked: 261 times
Been thanked: 1265 times
Do any owners put their original exhausts up for sale, when they “upgrade” to virile manly noisy ones?
Monstyr
Has thanked: 9 times
Been thanked: 94 times
Post by Monstyr »
I changed the endcans on my SC for a more aesthetic looking set, I installed the baffles that cost me about £30 from Keihin exhausts and am happy with the more muted tones, still not as quiet as the standard cans but it’s never caused me any issues, the open termi’s that were the standard upgrade for this bike were the loudest things I’ve ever heard on the road- louder than a desmosedici with its race system fitted.
I still have the standard endcans on my Monster, they are still the best looking cans I’ve come across, I did replace the cat with a bypass pipe and that give a pleasing sound without being really loud, completely legal too. In any case the only noise I can hear on that bike is the roar of the open airbox.
There’s different patterns of baffle, the ones shown already in this thread and the ones that have little ‘cutouts from the pipe bent inwards to soften the sound, I’m not sure if there’s any significant difference between them as far as noise is concerned
A_morti
Has thanked: 310 times
Been thanked: 568 times
Post by A_morti »
I have a CB300R. I fitted a Quill stainless exhaust on it. NOS from before they went bust in 2015!
I didn't realise it wasn't the T3 road-legal type that I'd had in the past but a race can with a basic token effort baffle. It reduces the outlet from 60.x mm to "a bit less than that" but that's all. It's just a tube and open at both ends. The 60.x mm is a weird size, and it has an angled outlet so I can't get a better baffle neither.
My solution was to get the removable catalyst used on various KTMs up to 450cc, and stick it between the silencer and link pipe. It turns out by a fluke that those fit really nicely inside my link pipe. This has really knocked the edge off the noise, plus it took away that "vintage" unburnt fuel smell you get without a cat. Plus Captain Planet no longer has to personally kick my arse.
This guy sold me mine, and has a few in stock:
https://www.ebay.co.uk/sch/m.html?_ssn= ... r&_sacat=0
You can also get similar looking things from eBay which don't have the Catalyst function, but will still knock off a decent amount of noise.
edit: mine was part number 79105091000, looks like he has only one right now. Part number 77005091000 probably comes off a two stroke, IDK if it would be suitable for your bike. Looks a weird fitment.
