Stolen from the Internet, so it must be true
Writing and reviewing a risk assessment before undertaking an activity is a great opportunity to take a mental pause in your planning, to really consider the 'What if?' and 'What could possibly go wrong?' aspects. Then, obviously (I'd hope) do something about them!
Sometimes you need to think creatively and try to include the more unlikely - but potentially catastrophic - events. Whether you want to consider those events as 'black swans', or perhaps it's just a sneaky little black mouse quietly nibbling a bigger hole in your 'Swiss cheese' model, there are those times when the unlikely becomes horribly real.
So if you and your family are heading out to celebrate Halloween (or to use its old name: All Hallows Eve) and go 'Trick or Treating' (or to use its old name: 'demanding money with menaces' ), make sure that you consider the conspicuity of your children's costumes. No, that doesn't mean that you have to wear high-vis - although white 'revenge of the Mummy' bandages might help!
Instead, think of the mitigations possible: drivers will find it difficult to see all black outfits, so take care when crossing roads or when drivers are parking - particularly as you'll be out in residential areas, where cars are likely to be starting and pulling out of driveways (often reversing) or stopping, and drivers arriving home will be mentally 'switching off'.
Don't expect drivers to see you. Wow - zombies, aliens, vampires *and* the invisible man!
Have a fun evening!
Halloween Risk Assessment
- Has thanked: 6187 times
- Been thanked: 5087 times
- Has thanked: 2941 times
- Been thanked: 1882 times
Re: Halloween Risk Assessment
And there was me thinking it'd be safety advice for going into strange old buildings, opening old vaults, reading from books that you had to use a key to open and when you did all the lights went out etc.
No, that'd probably be the Scooby Doo risk assessment.MingtheMerciless wrote: ↑Fri Oct 29, 2021 7:14 pm And there was me thinking it'd be safety advice for going into strange old buildings, opening old vaults, reading from books that you had to use a key to open and when you did all the lights went out etc.
- the_priest
- Has thanked: 1874 times
- Been thanked: 2170 times
That is me scuppered in the usual all black clericals. However the black cassock and the ghostly white surplice would probably give me a shot at not being run over.
So: look left, look right, etc. and don't walk behind reversing cars. Sortedthe_priest wrote: ↑Sat Oct 30, 2021 1:22 pm That is me scuppered in the usual all black clericals. However the black cassock and the ghostly white surplice would probably give me a shot at not being run over.
Local church car park used to be used by courting couples in their cars. The vicar used to put the hood up on his [insert hooded clerical clothing item name here] and stalk through the shadows. Go for it
