All singing, all dancing expeditionary roof rack.
32mm Aluminium construction, seam welded with full mesh floor.
Designed to go on the 100 Defender, G-Wagon, Transporter and more - just choose your brackets!
275 x 125 x 20cm 37kgs with a capacity of 200kg.
Multiple light mounts, tie down hooks, etc.
Manufacturers speil
The Direct4x4 expedition roof rack range offer stacks of solid load space and can open up a world of opportunities with fully compatible add-ons such as side awnings. Keep your luggage or cargo safe and secure during your overland adventures.
"Made from heavy-duty lightweight aluminium (~50% lighter than steel counterparts) with a robust 32mm diameter sub-frame.
Multiple 9 inch secure steel brackets down each side of the rack that easily fit to your rain gutter to keep your cargo firmly in place.
A massive 200kg maximum load capacity thanks to the heavy-duty frame and resilient diamond mesh design.
Matte black powder-coated finish looks great on any offroad vehicle.
Space for up to 5 spotlights provided on the front edge of the frame, hole diameter is 12mm.
Easy to fit, remove and maintain.
The full expedition rail offers a sturdy full basket frame to prevent cargo from moving about. Also offers a convenient handrail when loading and unloading the rack."
Currently fitted directly to our hi-cap Hilux but will obviously fit anything you want it to using their brackets for your vehicle.
These are £860 when in stock of which there is currently none so grab a steal on this.
£650 collected from South Wales although as this is still fitted, it can within reason be delivered/meet point.
Expedition Aluminium Roof basket/rack
- Has thanked: 25 times
- Been thanked: 54 times
