Page 1 of 6
DH Gipsy engine 1/4 scale
Posted: Wed Apr 08, 2020 8:05 pm
by kendo57
Bought these castings from an internet site , they were made a few years ago and probably
been sat under a bench . They came with a set plans which looked quite daunting at first look.
I Decided to start with the crankshaft , a piece of en8 steel bar was purchased , milled down then the
centres for the main and big end bearings were centre drilled
Then more milling to form the rough shape
Transfer to the lathe , mount between the pre drilled centres and turn the bearings
Quite a lot of work later I have something resembling a crankshaft
Re: DH Gipsy engine 1/4 scale
Posted: Thu Apr 09, 2020 9:54 am
by iansoady
Lovely, I look forward to seeing more.
Posted: Thu Apr 09, 2020 11:43 am
by Yambo
Oh goody, an engineering build thread. I'll be keeping an eye on it!
Are you khd?
Posted: Thu Apr 09, 2020 11:45 am
by Lutin
Yambo wrote: Thu Apr 09, 2020 11:43 am Oh goody, an engineering build thread. I'll be keeping an eye on it!
I'll second that.
Top work, that man! :thumbup:
Posted: Thu Apr 09, 2020 5:41 pm
by kendo57
Yambo wrote: Thu Apr 09, 2020 11:43 amAre you khd?
Yes I was KHD
So I realised that maybe I should do the crankcase first because if I mess that up the
rest will be irrelevant .
I started by machining the base to give me a datum to work from
Then machined the top flat and bored through for the cylinder openings
I drilled and tapped the mounting holes for the main bearing caps and after machining the cap bases
flat I drilled through the caps and fitted them.
Next I set the crank up on my lathe and bored the main bearings
Also line bored the camshaft bearing
Posted: Thu Apr 09, 2020 9:23 pm
by GuzziPaul
Great we're getting it from the start. Whish I had the tools and the skill.
Posted: Sat Apr 11, 2020 8:57 pm
by kendo57
should have posted this earlier , machining the timing gear case on the end of the crankcase.
You can just make out the punch dots used for marking the boring for crank and cam
A piece of phosphor bronze bar to make the main bearings , first it was slit down the middle
The two halves were soldered back together ready for machining, if I did it again I would use super glue
after machining they are re heated and split
Posted: Sat Apr 11, 2020 9:07 pm
by kendo57
Piece of cast iron is mounted for turning the cylinders
After turning the basic shape the piece is mounted on the mill and the fins cut using 0.5mm saw
Then back on the lathe to bore
Machining channels for the mounting studs
Finished cylinders and you can see I have bored through for the eight camshaft followers.
Posted: Sun Apr 12, 2020 12:23 am
by Bomble
Absolutely amazing work. Would It be possible to give an idea of time for each process?
Posted: Sun Apr 12, 2020 11:34 am
by Lutin
What a neat way to make the split shells for the main bearings.
Do you need special tooling to machine the cast iron? Looks like it doesn't produce swarf but rather small chips.
Great stuff. Really enjoying this. :thumbup:
Posted: Sun Apr 12, 2020 1:29 pm
by kendo57
Bomble wrote: Sun Apr 12, 2020 12:23 am Absolutely amazing work. Would It be possible to give an idea of time for each process?
Not really , it varies so much , sometimes I spend hours and feel I have got nowhere then
other times I have a really productive run. A lot of time is often spent setting up the work piece
and cleaning up afterwards.
Posted: Sun Apr 12, 2020 1:38 pm
by kendo57
Lutin wrote: Sun Apr 12, 2020 11:34 am What a neat way to make the split shells for the main bearings.
No special tooling , the cast iron bar I used is really nice to cut and produces a lovely finish.
The downside is it produces chips and a lot of dust , so much that I hate using it.
When I cut the fins I was covered in dust along with my mill and lathe , unfortunately the dust is abrasive
so I needed to strip and clean everything afterwards.
Some cast iron forms a very hard skin when its cast which can be a problem to remove .
I have heard of people having to grind the surface off to get to the machinable material underneath
but luckily the bar I use is not like this.
Posted: Tue Apr 14, 2020 8:35 pm
by kendo57
Each cam lobe was formed individually out of silver steel then hardened
Eight cam lobes , three bearings , two spacers and the shaft all in silver steel
Each lobe was bonded to the shaft with Loctite using a 360 degree rotary table and dial gauge to set
them correctly
Finished camshaft
Posted: Tue Apr 14, 2020 8:48 pm
by kendo57
Con rods are roughed out of alloy plate
Then milled to final shape
Posted: Wed Apr 15, 2020 10:27 am
by iansoady
It gets better and better. Can't wait till it's started up!
Posted: Wed Apr 15, 2020 1:12 pm
by kendo57
iansoady wrote: Wed Apr 15, 2020 10:27 am It gets better and better. Can't wait till it's started up!
no pressure
Posted: Wed Apr 15, 2020 2:23 pm
by Yambo
kendo57 wrote: Wed Apr 15, 2020 1:12 pm
no pressure
You gonna remake the piston rings then?
Posted: Thu Apr 16, 2020 1:13 pm
by hilldweller
Respect with a big R.
A good way to fend off cabin fever.
Posted: Thu Apr 16, 2020 2:03 pm
by G.P
Marvelous !
I (would) rate this thread a five ! :clap: :)
Posted: Thu Apr 16, 2020 9:20 pm
Proper engineering.
Awesome work man. 8-)
