DH Gipsy engine 1/4 scale
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
Bought these castings from an internet site , they were made a few years ago and probably
been sat under a bench . They came with a set plans which looked quite daunting at first look.
I Decided to start with the crankshaft , a piece of en8 steel bar was purchased , milled down then the
centres for the main and big end bearings were centre drilled
Then more milling to form the rough shape
Transfer to the lathe , mount between the pre drilled centres and turn the bearings
Quite a lot of work later I have something resembling a crankshaft
iansoady
Has thanked: 72 times
Been thanked: 244 times
Re: DH Gipsy engine 1/4 scale
Post by iansoady »
Lovely, I look forward to seeing more.
Ian.
1952 Norton ES2
Yambo
Has thanked: 512 times
Been thanked: 1403 times
Post by Yambo »
Oh goody, an engineering build thread. I'll be keeping an eye on it!
Are you khd?
Lutin
Has thanked: 368 times
Been thanked: 383 times
Post by Lutin »
Yambo wrote: Thu Apr 09, 2020 11:43 am Oh goody, an engineering build thread. I'll be keeping an eye on it!
I'll second that.
Top work, that man! :thumbup:
kendo57
Post by kendo57 »
Yambo wrote: Thu Apr 09, 2020 11:43 amAre you khd?
Yes I was KHD
So I realised that maybe I should do the crankcase first because if I mess that up the
rest will be irrelevant .
I started by machining the base to give me a datum to work from
Then machined the top flat and bored through for the cylinder openings
I drilled and tapped the mounting holes for the main bearing caps and after machining the cap bases
flat I drilled through the caps and fitted them.
Next I set the crank up on my lathe and bored the main bearings
Also line bored the camshaft bearing
GuzziPaul
Has thanked: 59 times
Been thanked: 195 times
Post by GuzziPaul »
Great we're getting it from the start. Whish I had the tools and the skill.
kendo57
Post by kendo57 »
should have posted this earlier , machining the timing gear case on the end of the crankcase.
You can just make out the punch dots used for marking the boring for crank and cam
A piece of phosphor bronze bar to make the main bearings , first it was slit down the middle
The two halves were soldered back together ready for machining, if I did it again I would use super glue
after machining they are re heated and split
kendo57
Post by kendo57 »
Piece of cast iron is mounted for turning the cylinders
After turning the basic shape the piece is mounted on the mill and the fins cut using 0.5mm saw
Then back on the lathe to bore
Machining channels for the mounting studs
Finished cylinders and you can see I have bored through for the eight camshaft followers.
Bomble
Has thanked: 35 times
Been thanked: 42 times
Post by Bomble »
Absolutely amazing work. Would It be possible to give an idea of time for each process?
Lutin
Post by Lutin »
What a neat way to make the split shells for the main bearings.
Do you need special tooling to machine the cast iron? Looks like it doesn't produce swarf but rather small chips.
Great stuff. Really enjoying this. :thumbup:
kendo57
Post by kendo57 »
Bomble wrote: Sun Apr 12, 2020 12:23 am Absolutely amazing work. Would It be possible to give an idea of time for each process?
Not really , it varies so much , sometimes I spend hours and feel I have got nowhere then
other times I have a really productive run. A lot of time is often spent setting up the work piece
and cleaning up afterwards.
kendo57
Post by kendo57 »
Lutin wrote: Sun Apr 12, 2020 11:34 am What a neat way to make the split shells for the main bearings.
No special tooling , the cast iron bar I used is really nice to cut and produces a lovely finish.
The downside is it produces chips and a lot of dust , so much that I hate using it.
When I cut the fins I was covered in dust along with my mill and lathe , unfortunately the dust is abrasive
so I needed to strip and clean everything afterwards.
Some cast iron forms a very hard skin when its cast which can be a problem to remove .
I have heard of people having to grind the surface off to get to the machinable material underneath
but luckily the bar I use is not like this.
kendo57
Post by kendo57 »
Each cam lobe was formed individually out of silver steel then hardened
Eight cam lobes , three bearings , two spacers and the shaft all in silver steel
Each lobe was bonded to the shaft with Loctite using a 360 degree rotary table and dial gauge to set
them correctly
Finished camshaft
kendo57
Post by kendo57 »
Con rods are roughed out of alloy plate
Then milled to final shape
iansoady
Post by iansoady »
It gets better and better. Can't wait till it's started up!
Ian.
1952 Norton ES2
kendo57
Post by kendo57 »
iansoady wrote: Wed Apr 15, 2020 10:27 am It gets better and better. Can't wait till it's started up!
no pressure
Yambo
Post by Yambo »
kendo57 wrote: Wed Apr 15, 2020 1:12 pm
no pressure
You gonna remake the piston rings then?
hilldweller
Has thanked: 73 times
Been thanked: 51 times
Post by hilldweller »
Respect with a big R.
A good way to fend off cabin fever.
Brian
G.P
Has thanked: 1994 times
Been thanked: 1283 times
Post by G.P »
Marvelous !
I (would) rate this thread a five ! :clap: :)
Proper engineering.
Awesome work man. 8-)
