YAMAHA RZ350 RESTOMOD BY KEITH CARLSON
Posted: Tue Apr 06, 2021 7:17 am
Motorbikes, Sportsbikes, Adventure bike, Supermotos, banter, chat, friends and whatever else you can imagine. KTM, Ducati, Aprilia, Suzuki, Yamaha, BMW, Moto Guzzi, Laverda
https://revtothelimit.co.uk/
Thing is, the change in tail unit usually means the sidepanels won't fit anymore.The Spin Doctor wrote: Tue Apr 06, 2021 11:15 am At a glance it doesn't look too bad... then I spot the missing side panels, the speed block colour scheme that doesn't work with what appears to be an R6 seat unit, that horrible headlight, the weird instrument binnacle...
At least it has a battery... some of the stripped down bikes don't seem to have room for one anywhere!
I think people are using YZF125 wheels, but I bet YBR125 wheels are wider and lighter than LC or YPVS wheels, mine will be staying on it's skinny 18" wheels as I liked standard YPVS handling, I found the brakes good enough for the performance as well.Potter wrote: Tue Apr 06, 2021 1:50 pmBrembo TZR125R wheels are the ones to have. Well, they used to be but I think the YPM lads snatched them all up and now they're not common or cheap. I think if I was doing it again I'd use modern 125 wheels from any of the Jap bikes, they seem to be decent sizes and I bet there are plenty in breakers, spacers are easy to knock up.Le_Fromage_Grande wrote: Tue Apr 06, 2021 1:12 pm I'd be surprised if the spoked wheels aren't lighter than YPVS wheels, having taken the wheels out of my YPVS on Sunday I know how heavy they are.
Do they have drilled holes to attach 2 disks ?Le_Fromage_Grande wrote: Tue Apr 06, 2021 2:22 pmI think people are using YZF125 wheels, but I bet YBR125 wheels are wider and lighter than LC or YPVS wheels, mine will be staying on it's skinny 18" wheels as I liked standard YPVS handling, I found the brakes good enough for the performance as well.Potter wrote: Tue Apr 06, 2021 1:50 pmBrembo TZR125R wheels are the ones to have. Well, they used to be but I think the YPM lads snatched them all up and now they're not common or cheap. I think if I was doing it again I'd use modern 125 wheels from any of the Jap bikes, they seem to be decent sizes and I bet there are plenty in breakers, spacers are easy to knock up.Le_Fromage_Grande wrote: Tue Apr 06, 2021 1:12 pm I'd be surprised if the spoked wheels aren't lighter than YPVS wheels, having taken the wheels out of my YPVS on Sunday I know how heavy they are.
If you mean the 125 wheels, I've no idea, the YPVS front wheel has two discs.Yorick wrote: Tue Apr 06, 2021 2:49 pmDo they have drilled holes to attach 2 disks ?Le_Fromage_Grande wrote: Tue Apr 06, 2021 2:22 pmI think people are using YZF125 wheels, but I bet YBR125 wheels are wider and lighter than LC or YPVS wheels, mine will be staying on it's skinny 18" wheels as I liked standard YPVS handling, I found the brakes good enough for the performance as well.Potter wrote: Tue Apr 06, 2021 1:50 pm
Yes, I remember that. The idea of using a 125 wheel instead is a bit confusing.Le_Fromage_Grande wrote: Tue Apr 06, 2021 2:55 pmIf you mean the 125 wheels, I've no idea, the YPVS front wheel has two discs.Yorick wrote: Tue Apr 06, 2021 2:49 pmDo they have drilled holes to attach 2 disks ?Le_Fromage_Grande wrote: Tue Apr 06, 2021 2:22 pm
125 wheels are now wider than 350 wheels were in 1983 and the wheels are lighterYorick wrote: Tue Apr 06, 2021 2:58 pm
But do they have mountings for 2 disks ?Le_Fromage_Grande wrote: Tue Apr 06, 2021 3:05 pm125 wheels are now wider than 350 wheels were in 1983 and the wheels are lighterYorick wrote: Tue Apr 06, 2021 2:58 pm
https://www.motorcyclespecs.co.za/model ... 5%2008.htm
Though looking at the YBR it has a narrower back wheel, so maybe YBR250 wheels
https://www.motorcyclespecs.co.za/model ... 0%2007.htm
Added bonus, YBR250 wheels look a bit like LC wheels
Fecked if I know, and you can keep your skanky YPVS wheel, I don't need any more scabby old wheels in weird sizes.
Suzuki used to run the same fronts on GSXR 750s with twin discs and (IIRC anyway) GS 500s with one disc and a blanking cone shaped part.
250s were single disc, 350 double discs.demographic wrote: Tue Apr 06, 2021 5:44 pmSuzuki used to run the same fronts on GSXR 750s with twin discs and (IIRC anyway) GS 500s with one disc and a blanking cone shaped part.
Think the early LCs only had a single disc? But the same wheels as my XJ550 which had two (fairly crap) front discs.
