What's this?
Been thanked: 2727 times
What's this?
Smells of creosote and Erinmore Flake.
Has thanked: 1059 times
Been thanked: 1646 times
Re: What's this?
cheb wrote: Thu Mar 26, 2020 9:36 pm Smells of creosote and Erinmore Flake.
Dunno, smells like plywood and wet concrete to me.
Its the base for a transformer shed, in case you were wondering why on earth it needed a 400 thick concrete floor.
Has thanked: 12605 times
Re: What's this?
You should see the way they build houses over here. No chance of subsidence and it's quaint how they build the 'footings' :mrgreen:
Re: What's this?
Yorick wrote: Thu Mar 26, 2020 11:37 pm You should see the way they build houses over here. No chance of subsidence and it's quaint how they build the 'footings' :mrgreen:
One of my brothers mentioned the way they do it on the Greek islands, all concrete shuttered with planks and re-enforced to the max.
All to give the houses earthquake protection.
Same kind of deal where you are?
Yambo
Has thanked: 512 times
Been thanked: 1403 times
Re: What's this?
Post by Yambo »
Yay! A shed that I can escape to from my workshop/house!
As I'm under house arrest for the foreseeable future I've been doing a few 'shed' things in my living room as well as jobs around the house. At the moment my living room floor is covered with a sheet of polythene so that I can get some coats of epoxy and varnish on a new wheelhouse roof lining for the boat. The balcony workshop has been in use daily and I've made a cat scratching post for a friend and I'm part way through a ramp so that another friend's cat can get up to her balcony. I don't even like cats!
In the next day or so I'll be starting on two identical RC sailing boats for friends (I made one last year which is sitting in my hallway). I've made templates for all the bits and I've been trying to get a sheet of 3 mm plywood - but failing - so they'll be made out of 4 mm ply which I think I have enough of. This is the boat . . .
. . .and here's mine out on the water:
crust
Has thanked: 958 times
Been thanked: 713 times
Re: What's this?
Post by crust »
Excellent, our own dusty, cobwebbed part of the forum.
:thumbsup:
Buckaroo
Has thanked: 1047 times
Been thanked: 1108 times
Re: What's this?
Post by Buckaroo »
Yambo wrote: Fri Mar 27, 2020 7:15 am Yay! A shed that I can escape to from my workshop/house!
They look amazing; really impressed.
I've always been a into RC of any form: planes, helicopters, cars and boats.
Do you have the plans / schematics for your build?
Thanks for sharing these pictures.
Yambo
Re: What's this?
Post by Yambo »
The plans are $15 iirc from http://www.bearospaceindustries.com/boats2.html. They do plans for 3 boats and a load of aircraft. The sloop pictured is easily made with most of it being from 3 mm plywood. Other supplies are necessary of course, about 3.5 kgs of lead, some wire and tubing and of course some material for the sails but the plans are good and it all goes together easily.
I'm making another two for friends at the moment so we can race them but I'm having to use 4 mm plywood as 3 mm has been unavailable here for a few months. I doubt it'll make a lot of difference, they'll maybe be a bit heavier but I can adjust the lead weight to compensate.
