Super
Couchy
Has thanked: 360 times
Been thanked: 2246 times
Super
Post by Couchy »
Some sort of normal in the world
Re: Super
990. Damn, they're hard to beat.
First dibs on track
Has thanked: 5954 times
Been thanked: 3572 times
Re: Super
At least once a month I look at 990 Superdukes on the basis I could buy one and keep the 690. Can't get passed the money people tend to ask for them though as they are fairly old bikes now. Par for the course I know as all 2nd hand bikes are expensive in general and you make most of it back, but just think for £2k more I could get a near new bike. Pity as I've still not ridden one.
Couchy
Re: Super
Post by Couchy »
This one was £4K, cheap tbh for the revised model but there is little else like them, they work well on track and are great for wheelies.
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Re: Super
Post by Bigyin »
Did i miss a memo about the 999 ?
Happy new track bike day .....this month :D
Re: Super
Bigyin wrote: Fri Jan 29, 2021 5:34 pm Did i miss a memo about the 999 ?
Lol deffo missed that one yes
Re: Super
weeksy wrote: Fri Jan 29, 2021 5:36 pm
What happened then?
Re: Super
Supermofo wrote: Fri Jan 29, 2021 5:37 pm
What happened then?
It came it went, same thing that always happens
Bigyin
Re: Super
Post by Bigyin »
weeksy wrote: Fri Jan 29, 2021 5:38 pm
Last i saw was a bunch of painted Fila panels ......... as you said, wont be the first or last time ;)
Has thanked: 19569 times
Been thanked: 4950 times
Re: Super
You are mean, this made me go look at 990s on the selling site out here. Not as expensive as I expected!! :( (Sad face cos regardless, I can't afford one!! LOL)
Re: Super
Fun bikes. I likes them.
Couchy
Re: Super
Post by Couchy »
Checking the SD over it has some corrosion on engine cases so I’ll have the covers off and get them painted, rear spring the same so I’ve ordered a slightly stiffer new one. Apart from that it’s surprisingly good. Front discs though far none standard NG discs ? I don’t know them so I’ve sourced a good pair of standard brembos, I’ll service forks and send shock off to be serviced too. Fresh brake fluid and it’ll be ready to use. It has nearly new Bridgestone S21 on so they can stay for a bit too.
Re: Super
I don't think the covers are expensive. Or throw some GB racing at it
Scuffmark
Has thanked: 264 times
Been thanked: 191 times
Re: Super
Post by Scuffmark »
It does look very tidy in the pic... Even the fixings haven't turned the usual orange :D
Has the fueling been sorted ?
Sold my 07 SD to put the funds toward my MT10 but as good as that is I still miss the SD.
Couchy
Re: Super
Post by Couchy »
Scuffmark wrote: Sat Jan 30, 2021 9:02 pm It does look very tidy in the pic... Even the fixings haven't turned the usual orange :D
Never had an issue with SD fuelling, it’s a bit touchy but always got used to it and I’ve had 5 of them. Surprisingly the usual bolts aren’t orange it’s weird lol
Couchy
Re: Super
Post by Couchy »
Noticed the other day some oil under the KTM, I cleaned it down and had a look and it was from the oil tank drain bolt. Took it out and it had the wrong size copper washer fitted. Dealer had done oil change before it was delivered and obvs got it wrong. Fitted correct washer and all is well. Also fitted standard exhaust which I think looks a whole lot better
Image65C17F76-8973-46A0-A06B-AAEFA3DDECAF by Tony H, on Flickr
Bigyin
Re: Super
Post by Bigyin »
I thought it was going to be a "SOLD" post :)
Thats a keeper in your books :D
Re: Super
it might be if he'd actually ridden it.
I think he needs a day out on it, a bit of dry weather and a couple of hours playing. That'll settle it, either way.
Couchy
Re: Super
Post by Couchy »
I did manage a ride round the yard and a rolling burnout after I’d sorted it 🤣
But tbh I’ve no desire to sell it or more specifically deal with people, the akra exhausts will be sold so I’m happy holding onto it. I’ll start doing the little jobs, I’ve got a new rear spring to fit and while that’s off I’ll get the sprocket carrier, caliper carrier anodised again and all the bolts around the rear zinc coated. It costs little as the guys that do all that are in our yard. I’ll work my way forward and see what else needs doing too.
Then I’ll start on the amigo 👍
Has thanked: 1926 times
Been thanked: 1728 times
Re: Super
They still alway look like the have been front ended into a brick wall ...
