Reading windows 7 event log
Ant
Has thanked: 39 times
Been thanked: 227 times
Post by Ant »
With a hard drive mounted externally via an external dock, how can I interrogate the event log from this HDD which has a windows 7 os on it?
Thanks.
Ant
Re: Reading windows 7 event log
Post by Ant »
No that's not what I meant.
It's in a hard drive dock connected to another PC. So what I meant was, is there a way I can view the event logs? Is there a file somewhere which contains the logs/error messages?
Has thanked: 5450 times
Been thanked: 13085 times
C:\Windows\System32\winevt\Logs is where they should be on the other machine.
derek badger
Has thanked: 769 times
Been thanked: 1135 times
Post by derek badger »
I think unless you've exported/saved them you can only use the eventvwr mmc snap-in to view another Windows computer system logs if the OS is loaded - i.e. remotely connect to another running PC.
Ant
Post by Ant »
Thanks chaps. It's a bit of an odd one as it's a system which runs over two disks (not raid).
I think its the second hard drive which has failed. I did a windows check disk on it and it stopped going any further at a certain point and stayed like that for about a day. Then I used a disk utility from WD and it found bad sectors.
Ant
Post by Ant »
Although there were bad sectors, I managed to copy the contents over to a new drive and that's sorted the problem out, now the PC boots and runs fine, much quicker too.
The other issue I'd like to sort out though, is some time ago after windows update, the computer takes ages to actually load the windows environment. Getting to the log in screen is quick, but once the credentials are entered, it takes a while.
I've disabled a load of startup items in msconfig, so I wonder what else I could take a look at?
