Does the R1200GS LC have a power socket?
- gremlin
- Has thanked: 776 times
- Been thanked: 4514 times
Google maps is killing my already knackered phone battery. I have a UBS cable and an adaptor, but is there somewhere I can shove it?
I've had a quick squizz but can't see one. Is it hidden some with ruthless Teutonic efficiency?
- Has thanked: 5945 times
- Been thanked: 4928 times
Re: Does the R1200GS LC have a power socket?
Google (and some dude) says
The standard accessory socket is located on the left side of the bike just down from the rider seat.
Further reading, it might be under the seat. Bloody stupid place if it is.
- Has thanked: 7726 times
- Been thanked: 2401 times
It might be an option, so you might not have one.
Really? Fuggin beancounters shouldn't be allowed near designers ...
- gremlin
In fairness, it's a hire bike, so probably not loaded with extras.
Does have a faint whiff of piss about it mind...
- Bigyin
- Has thanked: 1418 times
- Been thanked: 2620 times
Make sure it takes a standard 12V plug as some manufacturers (Ducati) use Hella type power outputs that take these instead
https://www.ebay.co.uk/i/184476639435?c ... LqEALw_wcB
I would ring local BMW dealer and ask them rather than get there and find its the wrong type/not got one
It was an option on the R259 series (1100/1150 boxers), some have them, some don't.
BMW use the same type. (IIRC it's known as a DIN socket by the dealers)Bigyin wrote: ↑Wed Oct 21, 2020 3:52 pm Make sure it takes a standard 12V plug as some manufacturers (Ducati) use Hella type power outputs that take these instead
- Has thanked: 2632 times
- Been thanked: 1498 times
Yes, caught me out completely when my brother said "you can recharge from my BMW" when we took a trip to the Pyrenees a couple of years ago... well, I could have if I had had the correct plug on the end of the adapter.Rockburner wrote: ↑Wed Oct 21, 2020 4:37 pmBMW use the same type. (IIRC it's known as a DIN socket by the dealers)Bigyin wrote: ↑Wed Oct 21, 2020 3:52 pm Make sure it takes a standard 12V plug as some manufacturers (Ducati) use Hella type power outputs that take these instead
I ended up cutting the plug off, and just putting the bare wires under my own battery terminals - it was easier.
- Has thanked: 15604 times
- Been thanked: 9849 times
Same on the F800s. It sits below the frame on the right hand side by your knee, or would if mine had one. It has a blanking plug instead.Rockburner wrote: ↑Wed Oct 21, 2020 4:36 pmIt was an option on the R259 series (1100/1150 boxers), some have them, some don't.
