Unmasking the Aerospace-Grade Head Cover Gasket: The War on Thermal Drift and Seepage
Webike Japan
Has thanked: 10 times
Been thanked: 1 time
Post by Webike Japan »
The stock cover gasket on the Katana is made of paper.
It shrinks a lot when heated.
One option is to apply liquid gasket sealant in advance to areas prone to shifting,
but doing that makes it a real hassle to remove the cover next time (lol).
In fact, applying liquid gasket sealant near the cam chain tunnel
is a very effective way to prevent leaks,
and it’s a spot where the manual often specifies applying it.
Now, for the most effective solution:
reusing the gaskets from the domestic-spec 1100 Katana SR and SY models.
These have been changed to a metal material, and while they’re a bit pricier,
they eliminate any shifting or blow-by and provide excellent sealing, so I highly recommend them.
In response to requests for reproductions, a manufacturer that produces high-quality aftermarket parts has created a metal-coated head gasket.
Although they cannot be used on some models, this should be a lifesaver for many users.
https://japan.webike.net/products/26641218.html
Buckaroo
Has thanked: 1047 times
Been thanked: 1105 times
Re: Unmasking the Aerospace-Grade Head Cover Gasket: The War on Thermal Drift and Seepage
Post by Buckaroo »
Have you checked how many members of this forum own a Katana?
Posting your, often technobabble, content is really a waste of time if the answer is zero.
Has thanked: 2272 times
Been thanked: 2654 times
Buckaroo wrote: Tue Jun 23, 2026 5:38 pm Have you checked how many members of this forum own a Katana?
It's a bot.
