Luggage
Has thanked: 713 times
Been thanked: 2036 times
Luggage
Givi Monolock or Monokey. Any better than the other for whatever reason? My topbox just now is Kappa with the Monokey fitting but that is small and needs replaced so dont mind swapping to Monolock if any better
Re: Luggage
Kappa is just rebranded Givi.
IIRC Kappa is run by the daughter of the Givi boss, all the fittings are interchangeable.
Re: Luggage
KungFooBob wrote: Mon Jun 01, 2026 9:38 pm Kappa is just rebranded Givi.
Yeah i know they are the same but if Monolock is better/newer then i may change fittings. There was a full kit of Monokey fitting for just over £200 the other day but the side boxes looking like they were from the American Chips TV series. May have looked OK if i colour coded the lids. To late now as they sold.
MyLittleStudPony
Has thanked: 829 times
Been thanked: 586 times
Re: Luggage
Post by MyLittleStudPony »
IIRC Monolock was for small capacity bikes and Monokey was for all bikes. It's been a while though!
Trinity765
Has thanked: 3138 times
Been thanked: 3185 times
Re: Luggage
Post by Trinity765 »
I've gone for SW Motech the last couple of times. It's quality and looks good. Nothing has broken and in 100k miles.
I had the Blaze on the Streets and now have the Urban on the Hornet.
Has thanked: 5953 times
Been thanked: 3571 times
Re: Luggage
From Goggle AI
"Givi's two primary luggage lines cater to different riding needs. Monolock is lighter, budget-friendly, and designed for scooters or light commuting. Monokey is Givi's heavy-duty, premium line, built to withstand higher speeds and heavier loads for touring motorcycles"
I've got a monolock cos it was cheaper, load values are very low, I think something like 3kg but I've loaded mine with few days worth of stuff and sat at 90mph on the motoway with it ok. I should just AI'd it again!
"The primary difference between Givi Monolock and Monokey cases is their load rating: Monokey cases are heavy-duty and rated for up to 10 kg (22 lbs), whereas Monolock cases are lighter and rated for only 3 kg (6.6 lbs)"
Has thanked: 3003 times
Been thanked: 2522 times
Re: Luggage
I have a large Monokey set up, and have overloaded it substantially when touring without issue.
On a previous bike I had a medium/large Monolock and did the same, again without issue.
I suspect the load limits are set by lawyers with little grasp of reality but a strong desire to protect their employer.
Re: Luggage
Givi Monokey it is. Just ordered this rack
https://www.wemoto.com/bike/yamaha/fzs/ ... okey-plate
I can add the side mounts at a later date and until i find a nice new top box i am sire my old Monolock plate will fix onto the rack for the time being.
Cheers all :thumbup:
