AreThese Sprockets OK?
Has thanked: 12604 times
Been thanked: 8535 times
Need a new chain so not sure what to do.
Normalarily I'd just change them, but not sure of the availability over here.
The front is a 16 which is 1 lower than standard
Has thanked: 19553 times
Been thanked: 4948 times
Re: AreThese Sprockets OK?
Can't help on the sprockets, but I'm not sure you should put pics of bits of bikes with that much dirty gunk on them on this forum :angelic-green: :angelic-green:
:lol: :lol: :lol:
Sprockets look okay, your chain has tight spots
Le_Fromage_Grande wrote: Sat May 23, 2026 9:20 pm Sprockets look okay, your chain has tight spots
Yup. That's why it's getting changed
Ditchfinder
Has thanked: 861 times
Been thanked: 1069 times
Post by Ditchfinder »
Pfft call yersen a Yorkshireman, I've seen 80 year old Lancashire hags wi better teeth
I'm amazed you spotted that???
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
You already know the answer but are hoping to hear the opposite, right?
The sprockets are worn, which can be seen in the tooth shape. They will wear a new chain faster than new sprockets would. Also that wear means the hardened face is worn, and you don't know how much is left; they could already be on the steep part of the slope towards scrap metal.
It's up to you if you do the whole set or not. Nothing catastrophic is likely to happen if you don't, but you'll get more life off the new chain if you do.
A_morti wrote: Sun May 24, 2026 11:33 am You already know the answer but are hoping to hear the opposite, right?
I needed confirmation to find the combination code for my wallet :obscene-birdiedoublered:
wull
Has thanked: 977 times
Been thanked: 1857 times
Post by wull »
Yorick wrote: Sat May 23, 2026 11:21 pm
It’s as clear as day from the pics ffs 🤣 Stevie Wonder could even see that 🤦‍♂️
Been thanked: 3504 times
I've had chains with some links tighter than others and look like yours, but movement is still ok. I put it down to bike being parked up too much and maybe waxy lubes. If the links sit on the sprocket correctly I wouldn't worry too much, depends how stiff they are. Change the lot when you change and maybe a more oily lube.
