Page 1 of 1
Preventing Punctures.
Posted: Mon Feb 16, 2026 5:15 pm
Getting fed up of punctures. Tried the Tubliss system my pal runs but got more punctures than normal.
So now gone for 4mm inner tube on front.
I carry that spray can puncture repair, but often it's too late as the valve stem has been ripped off the tube.
Is there summat that I can put in before I ride?
I like to run both tyres about 10 psi.
Any advice?
Re: Preventing Punctures.
Posted: Mon Feb 16, 2026 5:16 pm
by cheb
Mousses rather than inner tubes?
Posted: Mon Feb 16, 2026 5:28 pm
cheb wrote: Mon Feb 16, 2026 5:16 pm
It's hard to regulate the tyre pressures. I can't stand up on the bike so ride sat down.
I can feel big differences with wrong tyre pressures.
Posted: Thu Feb 19, 2026 8:17 pm
I put slime in my tubes to try and reduce the gradual pressure loss. I then got a puncture and even though it shouldn't work, it did. It was only when i got home i noticed all the luminous green stuff over the inner mudguard and swinging arm and realised i had a puncture.
Posted: Thu Feb 19, 2026 8:20 pm
by Le_Fromage_Grande
Have you got rim locks, it sounds like tyre movement is ripping the valve from the tube rather than you getting punctures,
Posted: Thu Feb 19, 2026 8:21 pm
Le_Fromage_Grande wrote: Thu Feb 19, 2026 8:20 pm
Yup, they come as standard.
Posted: Thu Feb 19, 2026 8:23 pm
Yorick wrote: Thu Feb 19, 2026 8:21 pm
Not that then
Posted: Thu Feb 19, 2026 11:16 pm
Le_Fromage_Grande wrote: Thu Feb 19, 2026 8:23 pm
Not that then
Probably 10 mm big blobs of rubber, no sharp objects.
Infuriating
Posted: Sat Feb 21, 2026 5:28 pm
Move back to England. No nasty, sharp volcanic rock here, just mile after mile of lovely soft, muddy, rain-filled ruts and trenches!
Posted: Sat Feb 21, 2026 6:04 pm
Taipan wrote: Sat Feb 21, 2026 5:28 pm
I really miss rain and mud
