Sticking up ripped roof felt
- Has thanked: 1926 times
- Been thanked: 1728 times
My house have concrete tiles - under these is what I would call "roof felt" - a bitumin base "felt" layer. In a couple of places in the attic, this has ripped - and because of the position facing south east, it means a howling gale blown though the attic when it is windy (90% of the time).
I want to patch up the rips - so I tried "Sticks like shit to a blanket" gorilla tape - it doesnt work! Then I reached out to the internet and came up with self adhesive roof flashing tape. 15 quid a roll and aboslutely useless.
How can I mend this ?? What else should I be using?
- Been thanked: 15488 times
- Has thanked: 8034 times
- Been thanked: 5692 times
Re: Sticking up ripped roof felt
Just about the only thing I've seen - that still only works for a while - is patches of felt slapped on using molten bitumen. Really, trying to fix it from the underside is an uphill struggle. (Got a similar problem and, tbh, I think that, with the concrete tiles as well, my permanent solution would be...a new roof with non-concrete tiles and new Tyvek barrier layerMr Moofo wrote: Sun Jan 18, 2026 4:34 pm My house have concrete tiles - under these is what I would call "roof felt" - a bitumin base "felt" layer. In a couple of places in the attic, this has ripped - and because of the position facing south east, it means a howling gale blown though the attic when it is windy (90% of the time).
- Has thanked: 7615 times
- Been thanked: 5927 times
Tyvek or similar, tacked on the underside of the roof timbers?
[As long as the roof is keeping the rain out. If not, new roof]
Roof is keeping out the rain . About 25% of the roof was replaced this year - so not looking at replacing any more of itHorse wrote: Sun Jan 18, 2026 4:52 pm Tyvek or similar, tacked on the underside of the roof timbers?
I was a bit surprised that, although the wind gets in, the water doesn't!Horse wrote: Sun Jan 18, 2026 4:52 pm Tyvek or similar, tacked on the underside of the roof timbers?
It’s under 8 solar panelsCount Steer wrote: Sun Jan 18, 2026 5:52 pmI was a bit surprised that, although the wind gets in, the water doesn't!Horse wrote: Sun Jan 18, 2026 4:52 pm Tyvek or similar, tacked on the underside of the roof timbers?
- DefTrap
- Has thanked: 1838 times
- Been thanked: 1468 times
I live in an old house and there is no underfelt or tyvek or anything. If you're just patching it up I'd use anything to hand and move on - the odd patch where the rest of the roof is basically sound isn't going to do any harm.
It just trying to find something that will stick to it!DefTrap wrote: Mon Jan 19, 2026 10:29 am I live in an old house and there is no underfelt or tyvek or anything. If you're just patching it up I'd use anything to hand and move on - the odd patch where the rest of the roof is basically sound isn't going to do any harm.
- DefTrap
Is there no way you can staple something over the gap and in between some rafters?
That's the planDefTrap wrote: Mon Jan 19, 2026 1:31 pm Is there no way you can staple something over the gap and in between some rafters?
- Felix
- Has thanked: 713 times
- Been thanked: 2036 times
When i stuck the felt down on my shed i used Black Jack. The paint, not the sweets
- Has thanked: 2287 times
- Been thanked: 2672 times
Wait, there's no plywood attached to the roof framing before the felt goes on?
- Been thanked: 2727 times
Not for the underfelt, in the milder parts of the UK.
It was either 20mm thick wood or OSB or plywood used as sarking on the islands because of the extreme weather
- Has thanked: 2852 times
- Been thanked: 3504 times
