The Halo effect?
The Martian
- Has thanked: 841 times
- Been thanked: 566 times
The Halo effect?
I was discussing the circumstances of my most severe RTA with someone and said about the halo effect (bouncing up and down headlight can trick the brain into thinking you're approaching much slower than you are) but I can't seem to find an article or proper description online.
I keep getting details of trendy headlight surrounds and not what I am looking for at all.
Any help from the knowing please!
Nordboy
- Has thanked: 580 times
- Been thanked: 828 times
Re: The Halo effect?
I've never heard of the halo effect, but it's very well known that headlights can make approaching vehicles speed very hard to judge. Much more so than just seeing a vehicle itself.
The Martian
I'm not 100% sure it's called the halo effect any more after struggling to find it online and now a man of your experience never having heard of it!Nordboy wrote: Thu Nov 20, 2025 8:13 am I've never heard of the halo effect, but it's very well known that headlights can make approaching vehicles speed very hard to judge. Much more so than just seeing a vehicle itself.
Hopefully Horse or SpinDoc still frequent the forum, they should make sense of what I'm on about hopefully
- Has thanked: 7618 times
- Been thanked: 5929 times
You called?
Whatever the name, I've not heard of anything similar.
I did read something, years ago, about over- and under-estimation of speed - but I've not found a reference since
There has been plenty of research on difficulties of assessing the speed of a single headlamp. Google "Mark Gould Thesis, Royal Holloway" and "time to arrival illusion" (which TfL used for a road safety video).
Potentially that leads drivers to see you, then either just pull out, or wait, then think "oh, not here yet, loads of room ... "
There's also the bump-flash issue, you hit a bump and your dipped beam which has been shining down then is visible to the driver. They think you're being kind, so pull out.
- Has thanked: 602 times
- Been thanked: 4528 times
I remember Voyager on VD used to claim that having your headlight on made the bike harder to see
- MyLittleStudPony
- Has thanked: 831 times
- Been thanked: 586 times
I find it best to observe any hazards well in advance. Then apply the brakes in good time.
Under some circumstances, possibly.Le_Fromage_Grande wrote: Thu Nov 20, 2025 4:28 pm I remember Voyager on VD used to claim that having your headlight on made the bike harder to see
https://en.wikipedia.org/wiki/Yehudi_lights
YupMyLittleStudPony wrote: Thu Nov 20, 2025 4:59 pm I find it best to observe any hazards well in advance. Then apply the brakes in good time.
Claiming 'priority' or 'right of way' is of little comfort if you end up as a bleeding, crumpled, pavement pizza.
- Has thanked: 19569 times
- Been thanked: 4950 times
Amazing how many cars still call priority (if they had a voice) in the face of a 19T bus!! Principle is the same, but slightly more protection (although I wouldn't argue with a bus if driving a car, or any vehicle really!!)Horse wrote: Thu Nov 20, 2025 5:01 pmYupMyLittleStudPony wrote: Thu Nov 20, 2025 4:59 pm I find it best to observe any hazards well in advance. Then apply the brakes in good time.
The Martian
Then finesse the clutch bring it up to 12 o'clock and up through the gears?MyLittleStudPony wrote: Thu Nov 20, 2025 4:59 pm I find it best to observe any hazards well in advance. Then apply the brakes in good time.
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
Samuel J. Levulis, Patricia R. DeLucia, Jason Jupe, Effects ofHorse wrote: Thu Nov 20, 2025 8:40 am You called?
oncoming vehicle size on overtaking judgments, In Accident
Analysis & Prevention, Volume 82, 2015, Pages 163-170, ISSN 0001
4575, https://doi.org/10.1016/j.aap.2015.05.024.
"The purpose of the current study was to determine whether overtaking judgments are
influenced by the size of an oncoming vehicle, and by whether a driver actively conducts an
overtaking maneuver or passively judges whether it is safe to overtake. We hypothesized that the
size of an oncoming vehicle would influence overtaking decisions because rate of optical
expansion is below threshold during high-speed overtaking, putatively leading participants to
rely on perceived distance and velocity. Results of Experiment 1 supported this hypothesis:
participants accepted more gaps as safe, and committed more false alarms, when the oncoming
vehicle was a motorcycle than a car or large truck, consistent with previous reports of the size
arrival effect on driving-related judgments (Caird & Hancock, 1994; Horswill et al., 2005). "
https://ttu-ir.tdl.org/server/api/core/ ... c9/content
- Contact:
Anecdotally, when the local lackwit on the BMW GS comes along the road with both main beam and auxiliary LEDs set on stun, it's easy to see the bike's lights, right up to the moment they're aimed straight at you, then you're blinded... even in daylight! After that, all you can see is the glare which a bike lurking somewhere behind it.Le_Fromage_Grande wrote: Thu Nov 20, 2025 4:28 pm I remember Voyager on VD used to claim that having your headlight on made the bike harder to see
