Gas bottle connections and turning on ??
Has thanked: 19571 times
Been thanked: 4950 times
I'm sure a few of you have used this sort of set up, maybe not in a home but caravan ??
Three of the cooker rings (hobs?) are gas here . Luckily, the fourth one is electric, so I've been able to cook ok !! LOL (Just only one pan at a time :lol: )
But, I've tried turning the gas, I think, on - there's a good chance the bottle is empty, but I don't want to head to the supermarket to change it if it's just me being and eejit and not understanding the process !!!
It's all connected up, but it's not everso clear which way to turn the 'tap' to make it on; or what the pushy button on the other side from the twisty 'tap' does?
Any help appreciated (then of course the obvious piss taking!) :lol: :lol: If I have to go get a new bottle, that's fine, just need to be sure I've tried the correct things to make it work before I do a 'disconnect' and purchase more :lol: :lol:
Re: Gas bottle connections and turning on ??
It's a clip on regulator, the button releases the clip so it will pull off the top of the bottle.
The lever all the way up is 'on'.
Has thanked: 3008 times
Been thanked: 1748 times
If it's got gas you'll hear it sloshing around when you move the bottle.
KungFooBob wrote: Sun Sep 28, 2025 11:54 am It's a clip on regulator, the button releases the clip so it will pull off the top of the bottle.
will go move the lever all the way up now!!
Pirahna wrote: Sun Sep 28, 2025 11:56 am If it's got gas you'll hear it sloshing around when you move the bottle.
I can't pick the bottle up from where it is, was trying not to disconnect it!!! But might have to to pull it out of the cupboard and see if it sloshes!!!
Has thanked: 7619 times
Re empty Vs full, in the UK gas bottles often have a thin metal disc in the neck, stamped with a weight. That's when empty.
Onto bathroom scales to check.
Edit: just seen that you can't pick it up
Has thanked: 24 times
Been thanked: 355 times
Post by ..... »
Post by ..... »
Rule of thumb, if you can pick it up, probably empty! A full one usually weighs @ 50lbs/22.68kgs/ bag of cement
..... wrote: Sun Sep 28, 2025 1:09 pm Rule of thumb, if you can pick it up, probably empty! A full one usually weighs @ 50lbs/22.68kgs/ bag of cement
I's gonna have to buy a wheelie trolly thing it seems LOL
I can pick this one up if disconnected, but am trying not to disconnect for now (not a fan of portable gas stuff unless camping sized!!)
I wiggled it in it's place and it did slosh a bit but even with the lever pushed all the way up, nothing seems to be coming out to light the hobs :( :(
Horse wrote: Sun Sep 28, 2025 12:47 pm
Been thanked: 2727 times
Another rule of thumb: A tap lever will point in the direction of flow if on and across if off
ace llani
Has thanked: 36 times
Been thanked: 45 times
Post by ace llani »
Boil the kettle. Pour the hot water slowly down the side of the bas bottle. shortly after, feel the temperature of the bottle. it will be cold where the liquid gas level is to, and be hot where there's no gas.
You lot are slipping. No one recommend holding a lit candle to the nozzle,then try the tap? :(
Has thanked: 714 times
Been thanked: 2039 times
Turn the knob off and press it in while pulling up the regulator to get it off.
There is probably a tap further up the line
Skub wrote: Sun Sep 28, 2025 8:17 pm You lot are slipping. No one recommend holding a lit candle to the nozzle,then try the tap? :(
Yeah but - it's me asking :angelic-green: :angelic-green: :angelic-green:
Ok, I'm pretty sure it's got gas in it, but I'll go disconnect it after I've finished this bucket of tea and see if I can
see another tap
check the slosh sound
refit it for a successful lighting of gas hobs !!!
Turns out I have zero patience !!!
Disconnected, shook it - some gas, but not loads (possibly a quarter full - ex-landlady, so reasonably good at sussing barrel contents, although not by shaking for the real ales :lol: :lol: :lol: )
Reconnected it and tried firing up the hobs again, but nope.
But I'd heard gas when I'd either connected or disconnected and couldn't find a second tap
Turns out it's totally simple - had to keep the buttons on the hob pushed down for a lot LOT longer than I thought !!!! LOL LOL
Sooooo - for approx 1/4 of a cylinder of gas I can cook on all four hobs, if I want to :bblonde: :bblonde: :obscene-drinkingcheers: :obscene-drinkingcheers: :obscene-drinkingcheers:
It's well over a decade since I cooked on gas for home cooking.
Damn it's hot !!!! I nearly killed my fried rice last night cos I didn't realise how hot the gas would get the pan !!
But, used again this morning and I really like it :) :) Just have to get used to using the smaller rings rather than heading straight to the biggest and fullest power :lol: :lol: :lol: :lol: :lol:
That bottle finally ran out a couple of days ago :o :o :o
Considering the new one cost me 23,90€ and I reckon the old one was about a third full (possibly a smidge less) when I got here, that's about 4 months cooking on the old and possibly 12 months on the new!!
I'm liking this gas cooking - since my electric bill has been horrific.
Think the electric towel radiator in the shower room (second coldest room) was madly expensive, especially when I had all that cold air blasting through for about three months :( :(
I've now turned the towel rad off to see, but might just have to get a timer plug for my oil filled rad so it just heats in the morning before I use it, or something like that
Noggin wrote: Wed Feb 11, 2026 5:38 pm That bottle finally ran out a couple of days ago :o :o :o
We (wifey and I) usually get well over a year out of a gas bottle. That's mainly using the hob with occasional grill and rarely oven. If I need an oven for seriously stuff I use the gas BBQ.
