Laptop memory
Ant
Has thanked: 24 times
Been thanked: 161 times
Laptop memory
Post by Ant »
My laptop takes PC3 12800 ram. Will PC3L work with it?
Ta.
Ant
Re: Laptop memory
Post by Ant »
Sausages.
exportman
Has thanked: 8 times
Been thanked: 64 times
Re: Laptop memory
Post by exportman »
Hi
PC3 L is low voltage 1.35V against standard PC3 which is 1.5V. if you change all ram to PC3L it should be OK if you try running both it may cause problems
wheelnut
Has thanked: 929 times
Been thanked: 917 times
Re: Laptop memory
Post by wheelnut »
Just go to crucial.com and run the scan tool. It will tell you what it will take.
