Lockers....
Has thanked: 780 times
Been thanked: 3224 times
Lockers....
....which don't lock :wtf:
I'm after something (additional garage storage for BBQ kit) along the lines of the below lockers, but with doors which don't lock, I can't find owt and am probably not using the right terminology, any ideas?
If worst comes to worst I will just buy lockers, remove the locks and have a couple of magnets on each door. :banana-wrench:
Been thanked: 15510 times
Re: Lockers....
Aren't they called cabinets then instead?
Kitchen stuff maybe?
Re: Lockers....
Re: Lockers....
Yeah, maybe, but they tend to not come in the narrow form factor that I need from a 'locker'
Has thanked: 8048 times
Been thanked: 5698 times
Re: Lockers....
Filing cabinet do the job? (Probably wider than you want).
Stackable units?
Re: Lockers....
Filing cabinet would work and aren't too wide, I've got 500mm to play with, but you lose vertical storage, and being a bit of a tart just don't have the aesthetic I like.
I've ended up with several odd spaces in the garage, all too small for proper full size cabinets or shelving.
Re: Lockers....
MrLongbeard wrote: Wed Jun 18, 2025 8:17 pm Filing cabinet would work and aren't too wide, I've got 500mm to play with, but you lose vertical storage, and being a bit of a tart just don't have the aesthetic I like.
I haven't looked too deep into their available options but Slingsby is my usual go-to option for this sort of thing. Can be spendy but I've been happy with what I've had from them.
https://www.slingsby.com/storage-shelvi ... lving.html
Re: Lockers....
Ikea have come up trumps, order one of these'
Re: Lockers....
That'll do, although I have sweated a river down my arse crack building it outside today
