silent compressors ?
- Been thanked: 15488 times
https://www.sgs-engineering.com/sgs-pro ... -1hp-45cfm
So i was thinking of getting one of these for inflating tyres. Yesterday i had one which the rim was slightly dinged and i couldn't get to seat on the bead. I was heading to my mate at his shop anyway so took the wheel, what do you know, with a compressor it popped straight up.
He had a Bambi, but they're a bit too spendy... so was thinking of this SGS.
I then need a hose kit to get the Presta inflated, but that can wait for a bit more ideas/discussion.
Any experience of these then?
- Has thanked: 1926 times
- Been thanked: 1728 times
Re: silent compressors ?
I don’t have a silent one - just as similar powered one that is branded Draper.
Had it for 5 years - and only gets used for seating tubeless. It’s excellent
Mine was about 90 quid at the time
Yeah the Bambi was proper proper silent... like insanely so.. You barely knew it was running.
I don't think the SGS is quite in that league... but fairly silent would be nice.
How do you deal with the Presta side of things, valve core out to seat it ?
There's the Park Tools INF-2 which is apparently amazing... but spendy
or a few things like this Prestacycle head which is a bit less spendy.
I have one of these which is basically the same as you linked too and I think it's great.
It is no where near silent but it's quiet enough not to piss my neighbours off.
Takes maybe 4 mins to fill up when switched on from empty.
The Tank pressure switch is set to around 100psi and you can easily adjust the regulator
so that you get anywhere from 0-100 out of the air line which comes in very handy when my friend
cant seat his tubeless tyres on his mtb rims.
With an airgun plugged in to it and trigger held on the tank pressure doesn't drop below about 25/30psi
Asfar as presta valves go thats what he uses on his bike too and we just use the cheap presta to Schrader adapters
and use normal car tyre inflators.
https://hyundaipowerequipment.co.uk/hyu ... bPZhKOLmtD
I've bought it and the host/attachement kit for now. It's only a cheapy attachment kit but it'll do for some testing.
https://www.sgs-engineering.com/5-piece ... ressor-kit
- Has thanked: 8035 times
- Been thanked: 5694 times
Comes with a dedicated operator/engineer/noise detector!Eclipse wrote: Wed May 28, 2025 8:47 am I have one of these which is basically the same as you linked too and I think it's great.
I just use one of those cheap brass adaptersweeksy wrote: Wed May 28, 2025 7:33 am Yeah the Bambi was proper proper silent... like insanely so.. You barely knew it was running.
silent may be stretching things a little... but pretty quiet is deffo there. Good enough that it wouldn't massively disturb a conversation anyway.
IMG_20250529_112531 by Steve Weeks, on Flickr
IMG_20250529_112531 by Steve Weeks, on Flickr- weeksy
Question then.
Assuming it's used like once a month or so, do you leave it full or empty? Takes about 45s to fill it, so it's not a question of time really.. more from a safety/normal practice perspective.
- Been thanked: 2727 times
I leave mine full of air but with the power turned off. It'll take years to corrode through, and even more if you drain the take every decade or so.
I'd suggest a good buy would be safety couplings for the air hose. They have to be depressuried before they release, there's a possiblity that normal ones can decouple by accident when being dragged about the floor.
I like PCL fittings: https://www.pclairtechnology.com/coupli ... fety-range
No worries. The Compressor won't move, the hose will rarely move... it could be a 5-6 times a year it actually gets used..cheb wrote: Thu May 29, 2025 11:56 am I'd suggest a good buy would be safety couplings for the air hose. They have to be depressuried before they release, there's a possiblity that normal ones can decouple by accident when being dragged about the floor.
No worries really then. My experience has been when using more than one hose and the coupling is on a roughish floor.
There's enough energy stored in the hose to flail it about alarmingly.
Right, it's question time.
https://www.ebay.co.uk/itm/235418173466 ... R_CbncDjZQ
This is the potential gun i'll get.
This is my Compressor
this is my hose
4 Meter Spiral Hose: The included recoil hose (with 1/4" BSP female couplings) connects all the tools to your compressor for easy reach
So, it looks like the connector on the Gun from Park Tools is a 3/8 and the hose i've got is a 1/4
What's the best way of making both compatible with eachother ?
It looks like the screw in connector on the PArk i could swap for the right type to go into a 1/4 connector ?
this is my hose
I'm tempted to just buy this though which will go straight on i think
https://prestacycle.co.uk/products/pres ... ation-tool
- Has thanked: 7619 times
- Been thanked: 5929 times
Since the introduction of music streaming services, dog's been out of work, so was happy to take on this new postCount Steer wrote: Wed May 28, 2025 8:52 amComes with a dedicated operator/engineer/noise detector!Eclipse wrote: Wed May 28, 2025 8:47 am I have one of these which is basically the same as you linked too and I think it's great.
- Has thanked: 2848 times
- Been thanked: 1609 times
Assuming it's a rotary screw type of compressor? Silent ones usually are.
Just make sure you turn it off at the mains when not in use - they have been known to catch fire if left on for long periods and the fluid level allowed to drop. Dealt with a few in the past (called Hydrovane) that did just that....
Beancounter
- Has thanked: 3126 times
- Been thanked: 684 times
Can't really add much except to say I've had the SGS 50l direct drive compressor for the last five years. It's noisy, like don't-use-before-8am noisy, but for £165 it's been a worthwhile purchase.
Used it a few times to seat motorcycle and mountain bike tyres. For the MTB tyres, I use a Presta/Schrader adapter which cost £3 from Amazon with the SGS gun. As you'd imagine, the gauge on the gun is not accurate which is likely why you're buying the Park Tool jobbie.
With hindsight, I could probably have got away with the 24l one but I had grand ideas of re-spraying fairing panels (it was during Covid)...
