Back to model making
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
Great to get back on my bike last year but winter came all too soon so i decided to keep myself busy
and get back into model making. Had an idea of what i wanted to do and after a bit of searching found
some free plans on the internet.
Its an Otto Langen engine , i believe the very first combustion engine running on town gas.
This is my first dry build , quite a lot of snags to fix but i hope to try and get it running one day
in the future.
dern
Has thanked: 1183 times
Been thanked: 2277 times
Re: Back to model making
Post by dern »
Cool. Do you make the parts yourself or is it a kit?
kendo57
Post by kendo57 »
Everything except the gears and flywheel are made from bar stock.
Flywheel has been machined down a fair bit and the gears are not worth machining as they can be bought
cheap enough and then machined to size.
dern
Post by dern »
Ah, I was going to ask you how you made the gears. Looks very cool.
kendo57
Post by kendo57 »
I've made gears in the past, just to satisfy my curiosity, they are not too hard to do as all you are really doing is cutting one tooth
and then replicating it around the blank.
The problem is its quite expensive to buy the cutters, probably more than the gears . You can make
you own cutters but its a lot of work and again not worth the hassle unless your making
lots of the same gears.
dern
Post by dern »
That's what I've found. I need the indexer and the cutters which is plenty of money when I can buy the gears from china and machine the appropriate thickness I need and the keyways.
silver991
Been thanked: 3 times
Post by silver991 »
That Otto Langen engine is a solid project. Gears can be a pain to make, so buying them and just adjusting makes sense. It’s cool that you're doing most of it from scratch though.
