..........Single Mixer Tap Hole.
Are they a standard size? I cant find my digital callipers to measure the tap but it looks like 32mm that slips through the hole. I need to order a wide washer in a hope to stop the cheap stainless steel sink flexing when you use the taps swivel head.
Cheers
Kitchen Sink...........
- Felix
- Has thanked: 717 times
- Been thanked: 2045 times
- Has thanked: 8048 times
- Been thanked: 5698 times
Re: Kitchen Sink...........
I found this:Felix wrote: Fri Jan 10, 2025 10:48 pm ..........Single Mixer Tap Hole.
Cheers
'People also ask
What is the diameter of a mixer tap?
What is the standard hole size for a mixer tap?
Re: sink taps
The hole size you are after is 30mm to a maximum of 32 mm but no bigger than that. Most modern basin mixers have a base size of 35mm some with extra base flanges that extend it out to 40 mm, but as a rule of thumb you never drill bigger than the base of the tap.'
- Felix
So probably correct at my tap being 32mm then. Best order a couple of different sized washers and a drill stepper as sure as hell when i take the old tap off it will be 30mm
