Penetrating oils
Sadlonelygit
- Has thanked: 94 times
- Been thanked: 796 times
Penetrating oils
need to replace a glowplug on the van. The internet says they need a damned good soaking in penetrating spray for a week before even looking at them.
Forums say pb blaster, which I can get, but is a bit pricey!
Others say 1:1 acetone and atf does the job.
Anyone with any experience of such things?
- Been thanked: 9495 times
Re: Penetrating oils
I was always told plusgas was the best.
I've watched video on the tinternets of people using crayons and candles wax to get stuff shifted too.
- Has thanked: 2556 times
- Been thanked: 4167 times
I'd reach for the PlusGas in that situation, as well. If there's a well around the glowplug that the penetrating fluid can sit in, all the better. Carefully directed heat from something like a MAPP gas torch to the area immediately around the glowplug prior to squirting in the PlusGas (or whatever) will also help.
But yes, glowplugs have a bad rep fer seizing in place...
Sadlonelygit
Apparently the regime is apply PF for a week whilst still driving around.
Pray to Mr Benz twice a day and don't use a mahoosive ratchet.
It would have been nice if it were one of the front plugs ie moderately accessible, but no, no4!
- Has thanked: 602 times
- Been thanked: 4528 times
- dern
- Has thanked: 1183 times
- Been thanked: 2277 times
I’ve never had to remove one but if I had to I’d take the car for a run to get the engine hot and then use plus gas on it and leave it for a while.
- Felix
- Has thanked: 714 times
- Been thanked: 2038 times
Only ever took them out with a hot engine and no oil. Yet to snap one but then again, i have only ever changed three sets and soon to be four.
- the_priest
- Has thanked: 2098 times
- Been thanked: 2558 times
PlusGas here. I used it on my totally rusted 23 yr old exhaust studs on the Triumph. Three weeks of spraying and heating with a bunson torch and then I used an extractor stud to remove them. They all popped out with no issues.
- Has thanked: 2289 times
- Been thanked: 2673 times
I can't believe no one has suggested KY yet. Iccy will be rolling in his grave!
Sadlonelygit
Does it cum with un chapeau specialeKungFooBob wrote: Mon Jan 06, 2025 10:17 pm I can't believe no one has suggested KY yet. Iccy will be rolling in his grave!
- Has thanked: 2848 times
- Been thanked: 1609 times
I dropped a load of PlusGas down the glow plug holes on my VW CC a day before I changed them, they came out so easily without as much as a squeek.
Sadlonelygit
wd40 penetrating oil has been bought. Need the weather to improve so I can crawl into the engine bay to start the spraying!
