A call out to lathe owners!
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Post by Sadlonelygit »
I require a couple of spacers to be made up, can anyone be of assistance?
Less than 90mm od iirc
89.1 od
84.1 id
Width tbc, but about 10-15mm
Re: A call out to lathe owners!
@cheb would be a good shout,though he hasn't been about for a while. (hope he's ok)
@Screwdriver would be another possibility.
Has thanked: 8035 times
Been thanked: 5693 times
Brickie, Kendo and Dern are all proud lathe owners. I think Eclipse may be too.
Nice little project for Dern and his new lathe. :thumbup:
dern
Has thanked: 1183 times
Been thanked: 2277 times
Post by dern »
I’ve only just started using it today so I need more practice before making something to spec. Sorry.
Also, you need to specify material op.
Sadlonelygit
dern wrote: Mon Dec 30, 2024 10:14 pm I’ve only just started using it today so I need more practice before making something to spec. Sorry.
Mild, stainless, brass, ally.
It's to locate a wheel centre on a hub so not material sensitive.....unless galvanic corrosion is included.
Doesn't have to be to the ⅒mm
Happy to be a guinea pig
Brass or ally would be perfect starter materials. :thumbup:
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
Count Steer wrote: Tue Dec 31, 2024 7:05 am Brass or ally would be perfect starter materials. :thumbup:
Have you seen the price of brass bar .
As for the spacers , they are a bit large for me , i have no bar that diameter .
Brickie
Has thanked: 4 times
Been thanked: 24 times
Post by Brickie »
I'll dig through my random materials box and see if I have anything of that size outer. I turned a part last week from memory 84mm outer - which makes me think I'd know if I had something that kinda size.
BTW: I don't class myself as a proud lathe owner, I regard taking on this sort of thing as more of a dirty habit.....
kendo57 wrote: Tue Dec 31, 2024 3:08 pm
Ah. No.....and I hadn't paid much attention to the size either. :D
