Yes, I know, pauper model machine. But it works.
E19 error code, which is the https://www.amazon.co.uk/dp/B01N4J4ONB? ... asin_title Discharge Valve
Power off.
Left side panel off, two screws on the front and 1 at the top at the back (left side panel facing the machine.
Discharge valve is the at bottom right of the unit. You need a towel under it to catch the water.
Unplug the valve, you gently tweak the blue tab back (right side) and should be able to tug the cable off.
Turn the valve clockwise to release it from the unit. Will require wriggling and gentle pressure to get it out. I tweaked it downwards and it came free fairly quickly. Make sure the end seal is out and the O ring is not left behind.
Replace new valve in reverse after seating it properly (flat screwdriver behind the valve and a gentle pressure for it to seat), then you can turn it anticlockwise for the tabs to secure it in place.
Reconnect the power, replace side plate and turn on to test. Mine worked straight off and no leads issues in the two days of use.
Less than 15 minute job for a £22.50 part.
Bosch Series 2 Dishwasher
- the_priest
- Has thanked: 2098 times
- Been thanked: 2563 times
