Has thanked: 2556 times
Been thanked: 4167 times
The standard lens is an 18-55mm zoom, and I was aware that the focal lengths are different in both shots, as is the angle I took them at. The XE-1 is a cracking little camera, light and small but with Fuji's famed colour balance.
I'm very interested in your mirrorless Nikon - does the absence of a mirror make a big difference? You won't get the 'clack', obviously and there should be shock and vibration improvements, but to be fair most camera manufacturers had got those issues sorted a long time ago.
We have a Nikon ZFC.
TBF by far the best/most useful thing is the lack of size! Mrs D uses it as an out-and-about Camera, it's great for that. We're not doing anything taxing enough to show its better than SLRs or anything else.
Live preview is great of course. She also does running photography gigs, the ultra fast burst is also good for that.
She was gifted a Nikon SLR and a whole load of lens by a friend who emigrated, hence the ZFC.
Nice! I can definitely appreciate the lack of size (and weight) thing. We were away in Italy for a long weekend at Cinque Terres and lugging a camera bag with two DSLR bodies and 4 lenses got really old really quickly. I was wishing I'd just taken the XE-1 after not very long...
So today the VFR passed its MoT (with no advisories) and the dealer fitted the centre stand spring so I now have a working centre stand. Hooray!
Small victories...
I'd like to know how they manage to fit things like centre stand springs, as they've always defeated me.
When I did the one on the Bonnie I think I had to hook the spring in place before bolting the stand in. That was the only way I could then have something to lever on/against to get the thing together.
I don't remember the details of what I was pushing on/against but I do remember the vague sequence :D
Yeah, I recall doing the LC's centre stand like that, but the layout of the VFR's stand, and the way the exhausts pass through the part of the stand near the frame mounting points meant it wasn't really an option.
I thik I'll Google 'spring expanders' and see what I get...
Don't they just use a spring puller and brute force?
Has thanked: 778 times
Been thanked: 3216 times
I know how to get existing springs off so that they're easy to put back on, put pennies (coin of your choice) between the coils whilst it is in extension.
actually no, you've got my memory
I rigged up a contraption with two bits of wire/cable, one to the ceiling joist and one to a 'stirrup', then I could use my bidy weight to expand the spring by stepping on into the stirrup. Then I wedged 1p coins in between teh coils of the open spring to hold it longer, installed it, then yanked the coins out with pliers.
Simple :D
KungFooBob wrote: Tue Jun 18, 2024 3:16 pm Don't they just use a spring puller and brute force?
S'alot of force for a soft palmed office nancy like me.
Has thanked: 10959 times
Been thanked: 3995 times
mangocrazy wrote: Tue Jun 18, 2024 3:08 pm Yeah, I recall doing the LC's centre stand like that, but the layout of the VFR's stand, and the way the exhausts pass through the part of the stand near the frame mounting points meant it wasn't really an option.
When I put the centre-stand on the Ed-80 I bolted on the stand, then was able to lever the spring on quite easily - because there's a large hex-nut head in just the right place to use as a locator for the screwdriver, and BMW, in their infinite wisdom, fit a metal clip between the end of the spring and the lug it fits onto on the frame: so - the lever (screwdriver) can go through the hole in the metal clip. Makes life very easy. :)
Part 3
The other way to do it is to use a length of thinnish line and route said line around something solid so you can pull the spring to length and hook it onto the lug (having a mate to help here is often useful!)
Rockburner wrote: Tue Jun 18, 2024 3:20 pm and BMW, in their infinite wisdom
I've no experience of working on a German bike, but I have worked on/lived with a couple of German cars (including BM) and I do have to say, they make a much better job of thinking these things through than most other OEMs IME :D
Mr. Dazzle wrote: Tue Jun 18, 2024 3:29 pm
I think it helps that BMW have been making bikes for so long... there's a huge amount of knowledge and experience within the organisation.
Obviously that would also apply to companies like Honda.
It does make you wonder though what they've been smoking over the years at Guzzi....
You may well be right. But I'm not really a brute force kind of chap...
Having said that, when I was installing the springs to hold two parts of the exhaust together I used a spring puller and ratchet strap in lieu of brute force. The strap was wrapped round the spring puller at one end and the forks at the the other end and I just manfully ratcheted away until the spring was sufficiently extended to pop it into position.
However the centre stand spring was hidden away in the bowels of the bike and there was no obvious way to use the same trick. So to the dealer it went.
OK, time to 'fess up. I've bought another bike. Even though I don't have enough room for the bikes I've already got.
And even though I've already got the same make and model of bike.
It's an Aprilia Falco.
A guy I know through the Falco Massive was selling his Falco due to divorce and cardiac issues (not sure if the two are linked) and his Falco had some fairly tasty upgrades (OZ Racing forged ali wheels, Ohlins shock, Ohlins internals in the Showa forks, full Renegade exhaust system and Renegade airbox conversion).
The only problem is, it's been sat in his ex's garage since 2017, and having committed to buy it was a bit of a shock at first sight. Filthy, covered in cobwebs and hardly enough air in the tyres for it to be capable of being pushed. But eventually I got it home, gave it a damn good washing and there is actually a motorcycle underneath all that grime. There is still more grime to be removed, but it's getting closer to being sanitary.
No photographs yet (have you tried photographing a black bike with black screen, covered in grime, oil and dust?), but they will be forthcoming at some point.
Today's task was trying to get the bike on SORN. It was already on SORN when Pete owned it, but that lapses on change of ownership. I have the new V5C in my hand, but no matter how hard I try, the online SORN system will not accept the code that's on the V5C. So the only way to sort this and avoid potential prosecution is to ring up DVLA.
Deep joy.
It took me an hour and 5 minutes to get through to a live, warm human being. While I was waiting I checked the oil on the van, topped it up, fed the cat, went to the local 24 hr shop to buy a can of pineapple chunks (it's pizza night tonight), and unpacked the Soulwax vinyl and the 5 litres of 2T oil I ordered.
But after an hour and 5 doing a Blondie, all was resolved in a couple of minutes. So patience does have its own reward.
Just thought you'd like to know.
Much Against Everyone's Advice is a great album.
KungFooBob wrote: Sat Jun 29, 2024 7:07 am Much Against Everyone's Advice is a great album.
That was one, the other was Nite Versions.
You're a monster.
It's obvious why in that long post, I don't need to spell it out. ;)
Mr. Dazzle wrote: Sat Jun 29, 2024 7:37 pm You're a monster.
It's the pineapple, isn't it? :D
Toto, I've got a feeling we're not in Sheffield anymore...
Yes, I got so pissed off with the English (lack of) summer that I legged it down to the south of France. On the VFR... I took the 8:00 ferry from Portsmouth to Caen on Monday (arriving at 15:00 French time), then rode down to Bourges where I stayed in a Kyriad Hotel on Monday night. On Tuesday I did the remainder of the miles, arriving at the Roujan supermarche at around 15:00 pm.
Unfortunately I don't live at the supermarche and the bike wasn't going any further as it had slowly drained all the fluid in the clutch reservoir until the clutch would no longer free off; not even partially. I'd noticed the clutch getting stickier, but hoped it would last the distance. It didn't. It expired about 4km away from 'home'. I then had to lug my belongings to the offices of the local Taxi service (in mid 30s heat) and beg them to take me the last few kms. Which they did, thankfully.
So this morning I made myself a big cardboard sign saying:
Roujan
Super-U
Merci !
and filled the tank bag with my helmet, gloves, a selection of tools and a bottle of Dot 4 fluid. And then proceeded to try and thumb a lift.
Thankfully it only took 10-15 minutes before a kindly soul stopped and took me to within a few metres of my poorly VFR. Equally thankfully, the tools I'd brought were the correct ones and in about 10 minutes I had the reservoir topped up and the clutch bled to a point where it was safe to use (it nearly had me off the previous day).
My overwhelming emotion was one of relief that I'd finally got the bike back in my garage. On previous occasions I'd quite enjoyed the extended trip down through France, and I still felt the same way about at least half of the journey, but the interminable stretches of autoroute through flat northern/central France were as boring as hell. As far as I'm concerned the interesting bits of France start around Clermont-Ferrand. Anything north of that is fairly dull and just plain hard work. I really am getting too old for this kind of shit.
At least the weather played ball. Northern France was cool and cloudy , but not rainy. The middle of France was 'cloudy bright' and the temperatures only kicked into high gear once I'd descended from the Massif Central and was about 50 miles away from my destination.
Anyway here's an old photo of the VFR and the Falco lollygagging in the sun outside the ancestral pile.
Has thanked: 4088 times
mangocrazy wrote: Wed Jul 24, 2024 11:02 am Toto, I've got a feeling we're not in Sheffield anymore...
Not sure about your timing,it's been raining at some time or all of the day for what seems like forever,but since last Friday it's been lovely around here,West Lancs & the 7 day forecast is more sunny weather :thumbup:
My old FZ750 has a hydraulic clutch & it has a near permanent leak on the clutch slave cylinder,I think the seal fails due to grit & muck being flung at it.Is it a common problem on the VFR? My XJR owning mate says that they're also known to fail.
