Trail braking, or braking in corners.
Re: Trail braking, or braking in corners.
You're in the right sort of ballpark though Cheesy, it's just a massively complicated set of interactions! This is why you have high and low speed damping, semi-active suspension, magnetorheo..can't spell it!...clever variable rate dampers. etc. etc.
Has thanked: 2556 times
Been thanked: 4167 times
Le_Fromage_Grande wrote: Fri Jun 30, 2023 10:10 am To be fair to me, last night I'd been in the garage with my Kawasaki running, so God knows how much warm unburn't petrol I'd breathed in, I woke up with a stonking headache this morning
Not to mention the carbon monoxide you'd imbibed. Glad to hear you got away with just a bad headache.
I wouldn't be at all surprised if it emerged that Ohlins MotoGP forks had some kind of variable rebound damping based on where they were in the stroke. At almost maximum depth of stroke you'd have increased damping, tapering off as the fork returned to full extension.
Perhaps. Maybe. It's the kind of stuff they'd be evaluating, I'm sure.
I was nearly killed by a CO leaking boiler a few years back...it's fucking sketchy, the very first symptoms are loss of judgement and mild euphoria, so you don't even realise you're getting deaded.
Needless to say, I have CO monitors now!
Has thanked: 357 times
Been thanked: 919 times
Far as I can see, trail braking is the same as the usual kind - on smoothly, off smoothly - it’s just that you’re doing it later than usual, i.e. when in the turn and leaning, as opposed to doing it all in a straight line before the bend.
Has thanked: 7619 times
Now here's a good YouTube training video :D
Screwdriver wrote: Thu Jun 29, 2023 9:45 pm Yorick is correct regarding the effect on the steering geometry and it's not a subtle effect either, the steeper rake angle as the forks compress, really quickens up the steering.
And a steeper fork angle also shortens the bike's wheelbase, further quickening the steering.
Mr. Dazzle wrote: Thu Jun 29, 2023 8:53 pm
10 points for the first person to say "traction circle".
@Mr. Dazzle Ooh, sorry, missed this.
1. Is it a circle, quadrant, or oval?
2. Is it a rare occasion where '1' can be worth more than '1'?
Has thanked: 2908 times
Been thanked: 1678 times
Horse wrote: Thu Jun 29, 2023 2:25 pm
slowhare wrote: Thu Jun 29, 2023 2:09 pm OK, but why would i need to?
I was taught old-school police-style, 40+ years ago. Back then *any* braking in bends was frowned upon :)
You'll rarely, if ever need to trail brake on road. However, see my earlier post, does that answer your questions?
Ignore the YouTube hype about "you must".
Did you not have a story about the copper on the training course picking himself and his BMW out of a hedge on a bend and saying proudly to the instructor "I didn't brake in the corner though"?
Horse wrote: Fri Jun 30, 2023 9:04 pm
But the loading on the front tyre compresses the contact patch making the bike want to sit up and go straight ahead. That's rather significant on squidgy, more rounded road tyres, less so on stiffer competition tyres. Try braking hard MID CORNER to see it in action. Just make sure you pick a bend with plenty of run-off. Braking hard on the way into the bend has the same effect, you just don't notice because it's easier to compensate by adding more steering torque.
On the road, ,ost of the 'quicker steering' effect people talk about is actually the result of the bike losing speed and turning on a progressively tighter radius as it slows down.
I still don’t get it: apart from braking later, are there any benefits (and why would braking later be a benefit).
Thank you in advance.
1) We don't get every bend right... it's easy to enter too quickly and then being able to brake into the bend is very useful
2) We may misjudge the radius of the corner or it may tighten up part-way round - being able to brake MID-corner is an equally useful skill
3) The road may turn out to be blocked just out of sight - stopping might be essential
The important thing to remember is that if you brake INTO a bend you start hard on the brakes then ease off as you add lean. And if you brake MID-bend then you start light on the brakes, then progressively hard if you can ease your lean angle.
Even gentle braking in a bend will get the bike slowing much quicker than engine braking along on many bikes.
And finally, if you haven't already crashed mid-corner, you have tyre grip to brake... gently.
Screwdriver wrote: Fri Jun 30, 2023 7:29 pm As an interesting aside, physics has come a long way in the past few decades with the event of supercomputers etc. but so far as I am aware, the actual dynamics of a bicycle/motorcycle are not fully understood. Perhaps I am not phrasing that quite correctly but I remember reading somewhere (probably while researching counter steering and slip angles etc.) that there is no equation or set of equations that describe how a motorcycle/bicycle actually steers!
This should offer you some decent info...
https://www.amazon.co.uk/Motorcycle-Dyn ... b_title_bk
The Spin Doctor wrote: Fri Jun 30, 2023 10:02 pm
Braking then wouldn't have been trail braking ;)
There was a suggestion that test candidates would sometimes disconnect a brake light switch. As if the examiner wouldn't notice that he was suddenly closing on the bike ahead ..
Screwdriver wrote: Fri Jun 30, 2023 10:58 pm No, I think you misunderstand the effect of "quicker" steering, it means you can adjust your line mid bend with less steering input which places less additional load on the front tyre than a bike with less castor.
Well, it depends on your perspective. I'd say that most people would understand 'QUICKER' steering to be a faster change of direction by speeding up the rate of roll for a given input.
In any case, two sides of the same coin, both of which you can achieve by changing the STATIC steering geometry of the machine.
The effect you refer to when a bike wants to sit up mid bend is because loading the tyre causes the front wheel to countersteer. It is because the contact patch is offset from the centre line of the bike, on the inside of the turn. The wheel therefore steers into the bend and like kicking the bottom of a balanced pole, the top falls the other way.
If I recall correctly, I drew you a diagram explaining the effect of an offset tyre contact patch when discussing hanging off mid bend.
Agreed 100% and I've been explaining how this DYNAMIC change to steering geometry works for at least two decades! I don't think it was me you had to explain it to since I was talking about this sit-up tendency on the brakes way back on my old website, long before the earliest days on VD.
I'll take your word for it if you insist there some squishiness going on but the primary effect is due to the offset contact patch which will be more pronounced on wider tyres.
I don't 'insist' but as far as I know - and my source was the head Avon tyre technician at a rider skills day at Castle Combe - race tyres have a different carcass construction which is much stiffer to give more precise control under hard straight line braking and at extreme lean angles, whereas road tyres have to be a compromise because of the need to be compliant in order to deal with the bumps found on a typical road.
And since the tyres compress more under braking, that broadens the contact patch, and should you be leaning over when you brake, the offset will inevitably be greater on a road tyre - and that will increase the self-centering tendency of the bike and make it want to sit up.
Has thanked: 778 times
Been thanked: 3216 times
Wait, use the rear brake you say :think: :think:
Screwdriver wrote: Sat Jul 01, 2023 12:41 am
MrLongbeard wrote: Sat Jul 01, 2023 12:34 am Wait, use the rear brake you say :think: :think:
Yeah...?
Weird man, weird.
Screwdriver wrote: Sat Jul 01, 2023 12:21 am Sorry but if the tyre squidges or is rounder, there will be less offset and less tendency for counter steering which is (I suggest) the principle action here.
If it flattens out, the contact patch broadens. Think of the difference between a V and a U
If you lean the V over, the contact point ALWAYS remains the tip of the V with zero offset until you lean so far the side of the V is on the deck.
If you lean the U over, the contact patch quite clearly moves around the circular portion progressively with the offset in a direct relation to the lean angle... and so the offset INCREASES steadily with more lean.
Similarly a stiffer carcass will resist movement and maintain the maximum offset
Depends on the profile. A stiff triangular tyre will have minimal offset.
(if carcass deflection was a contributor to the effect).
And it is, according to Mr Avon.
"Explain" is perhaps too suggestive, you wanted my graphic for a book or something... It was showing why a wide tyre has a greater offset meaning the centripetal force from the cog through the tyre (lit. v.v.) could be displaced towards the contact patch, ideally right through it, if you "hang off" the bike.
I honestly don't remember that at all - as I say, the effect of the offset contact patch on steering is is a concept I've been talking about online for a couple of decades. Not to say it didn't happen but like Ronnie R. "I don't recall".
Again, I would expect a softer tyre construction would actually "smear" out the effect whereas a stiffer construction would maintain a much more tightly focussed action. Like the difference between trying to balance on a bean bag or a basketball. That would tie in with your Avon chaps description because a stiff carcass on a bumpy road would throw you all over the place since the effect is not dampened or smeared out due to contact patch compression.
Yes - as an inflated tyre behaves rather like a balloon bouncing on a surface - hit a bump, and the tyre will compress and flatten, then bounce back and regain its rounded shape. The result is that the offset changes and creates 'bump steer'. The worse the bump steer, the more smooth handling in corners is compromised.
Screwdriver wrote: Sat Jul 01, 2023 12:45 pmThe bike does not stand up mid bend because of tyre deflection, it stands up because more pressure on the inside of the tyre causes countersteering.
I'm completely failing to understand why you're debating this with me. DEFLECTION in these terms can be defined as "movement or displacement of the steering mechanism" - the offset contact patch caused by the leaning tyre creates a torque on the wheel to which the tyre's fitted, turning the steering to face INTO the corner, which in consequence creates a counter-steering action which results in the bike standing up.
And as you accept that, I would have thought that it would have been obvious that the more you shift the contact patch's offset away from the centre line of the steering axis, the greater the torque - and consequently the greater the righting moment - that's created.
And if you accept that, I struggle to see how you can't also accept that the PROFILE of the tyre also matters - the rounder the profile, the more offset in the contact patch for the same angle to lean is easily demonstrated with the V and U analogy.
And if you accept that tyres DEFORM by compressing under braking forces, then it follows that the contact patch must get wider and longer. Upright, that doesn't matter, but as soon as you lean the bike over the wider element of the flattened contact patch MUST be offset further from the steering axis when compared with a tyre which retains its unloaded profile.
And that MUST make the effect of braking into a turn increase the tendency of the bike to sit up.
I spoke to an anonymous tyre expert earlier and he says I'm right, so I guess that cancels out your anonymous expert.
If I looked hard enough, I could undoubtedly find his name.
Just me and you and I am not convinced by your argument. Glad to see you picked up on my earlier explanation and present the exact scenario I just described to you back to me calling it "bump steer" which of course it is but it does that for the reasons I stated. Not yours.
I would say that I didn't "pick up on your earlier explanation" but have been saying the same thing consistently - maybe just a bit more clearly and in rather more detail.
:crazy: Whooopee
Another interesting thread fooked :(
Righto. I’m going to try to return the thread to whence it came. I don’t habitually “trail brake” when I’m riding on the road, which I do fairly briskly but keeping something up my sleeve, just in case. I do wonder how much smoother/ better/quicker/(safer) a trail braker would be riding in my company. To be worth doing, I suspect they’d be closer to the limit, i.e. at greater risk, much of the time, and I’d bet they’d be very little quicker across country. In other words, it’s a track tech with little useful relevance to road riding. And yes - I’m quite happy to brake in bends, tighten lines etc when needed, but don’t use tb as routine.
There now….
